Thanks for your input here. Was the leak resolved, and what was the culprit? My Grenadier just showed droplets on the dash under the camera for the first time after 9 months. Bummed for sure...Look forward to hearing what Triad has to say!
I had the same issue with the safari windows. The dealership couldn’t fix it the first time, but after replacing the rubber seal, the problem was solved.Thanks for your input here. Was the leak resolved, and what was the culprit? My Grenadier just showed droplets on the dash under the camera for the first time after 9 months. Bummed for sure...
Your drips were on the dash like mine? My drips seem like they are coming down from the windshield camera/rearview mirror which seems like good distance from the safari windows.I had the same issue with the safari windows. The dealership couldn’t fix it the first time, but after replacing the rubber seal, the problem was solved.
Yes, the same spot. Water travels to the lowest point of the roof.Your drips were on the dash like mine? My drips seem like they are coming down from the windshield camera/rearview mirror which seems like good distance from the safari windows.
The same thing happened to me a few months after having the car, when it rained hard the roof of the car got wet but only the right part of the roof, around the safari window. At first I didn't know what the problem was. I took it to the official workshop and they put silicone around the rubbers of the safari windows but one day when it rained hard water came back through the ceiling. Tired of not having the problem solved in the workshop, I decided with the help of a friend to move the roof rack backwards, remove the safari windows and see what the problem was. The drain of the right safari window was blocked and did not evacuate any water. We unclogged it by putting pressurized air on it and everything worked properly even in heavy rain.Thanks for your input here. Was the leak resolved, and what was the culprit? My Grenadier just showed droplets on the dash under the camera for the first time after 9 months. Bummed for sure...
@OverlandGearGuy Rob, are you still making these magnetic covers for the outside of the safari windows?Just a gentle reminder, I had overland gear guy make me a custom magnetic cover that spans over the outside of the safari windows. You put it on when you are parked and then take it off before driving. It rolls up easy and is simple solution to keep the safari window area clean.
