Leaking - Multiple Areas
Yes, the seals have been changed on mine, but it still leaks. There is water ingress along the entire top end, drips along the inside panel and then drains down into the recess at the bottom. I often find a puddle where the bottom latch is.
If you park on the flat or facing down hill, is it then ok?
Best I can tell is that the rear door seals are not sealing. If the water can get to the upper lip, it's going to trickle in. Sitting flat or other wise does not make a difference.
The safari windows, seem ok for now. I have not opened them since the garage did the re-seal and re-fit. I had a root around this evening to confirm and couldn't find any water or damp anywhere in the front driver or passenger side.
I continue to park at either a +10 Deg or if I am being lazy at a -10 Deg incline at home, in the open.
Reactions: CRH
