- Local time
- 10:37 AM
- Joined
- Mar 9, 2022
- Messages
- 545
If I wanted to replace my house battery with a lifepo is it possible? Everything else is stock. What size battery is it currently?
I would love to see some photos of this installation!In a word, no... More correctly, not in an ideal fashion.
The charging profile of our smart alternators will not appropriately or fully charge a LiFePO4 battery (or truly, anything that doesn't fit the pre-programmed charging profile of an EFB). So you'll need to introduce a DC-DC charger.
On the plus side, if you have the OEM dual battery set up there is an option that is very straight forward. Grab the RedArc 150Ah LiFePO4 battery and RedArc BCDC Alpha 50 DC-DC charger and then grab the @GPFACTOR mounts for both the battery and charger. I recently helped @TWExplor install this setup (granted, I made a DC-DC charger bracket for him because GP Factor didn't have one at the time). We were able to reuse the OEM house battery positive and negative cables, and utilized the OEM 5 outlet bus bar to be power distribution for the aux battery. Grabbing power to the DC-DC charger from the main battery was easily done by replacing the ZCASE fuse that normally lead to the SmartPass with an appropriately sized one and making a new power wire.
Please tell me, if i am wrong, but i checked that situation with CTEK, and they told me, this is not a problem at all.Yes, it is possible to replace your house battery with a LiFePO4 battery even if everything else is stock. However, you might need to adjust your charging system or install a DC-to-DC charger to ensure optimal charging and lifespan of the LiFePO4 battery.
I just took this from a Google searchPlease tell me, if i am wrong, but i checked that situation with CTEK, and they told me, this is not a problem at all.
The CTEK 120S can handle one EFB (Starter) and one LiFePo, and takes care about the charging procedure - at least that is what i was told. I replaced that EFB House Battery with a ECTIVE LC 150 Dual LiFePo, and it almost fits perfecly (just very minor shavings at the plastic foot on the door side).
This is the answer i got from CTEK:I just took this from a Google search
Seems like you have to have a combined smartpass 120s and a D250se to charge a EFB starter and LiFePo battery house battery.
OK I stand corrected. Must be ok if they say so.This is the answer i got from CTEK:
Dear Martin
Thank you for contacting us!
A start battery should never be deeply discharged and should be capable of delivering high current for a short period of time.
The starter battery should be a Lead Acid battery designed for automotive applications. This does not affect the chemistry chosen for the Service battery.
Smartpass 120S is compatible with a LiFePo4 Lithium as a service battery battery.
In your case it is possible to replace.
Lifepo-Tech sheet says:The 120S loads with 120A:
That is quite a lot for a Li-Battery; typically it is 0.2 C, so in your case 150 x 0.2 = 30A. Anyway, check the battery specs and "Versuch macht klug".
No, the LC-150 Dual - Would work also as starter battery. But because i am not sure how the loads are spread, when you use a winch, i'll prefer to keep the EFB as startet ;-) But it can handle for starting 1650 A (for few seconds) Also low temp. charging till -20°. I need that for trips in scandinavia in the winterIs it the ECTIVE LC 150L?
https://www.ective.de/batterien/lithium-lifepo4-batterien/lc-150l-bt-12v-lfp#tab-attributes
They recommend 60 A for charging, with max 100 A.
For sure you'd have to do many ajustments to make it fit somehow. It is bigger and needs to be held down from the top. So not really a drop in replacement.Is this a possible candidate: https://eu.renogy.com/products/core...hosphate-battery-w-low-temperature-protection
