Inverter install with rear drawers.
countscarecrow
8:56 PM
Australia
I'd like to install an everkool 40L draw fridge and draw, just wanted to know if anyone else has a similar setup with an inverter and where they installed it in the wing, what size brand and how much plastic they removed. Or i make room behind the draw. Preferably a 1500w or higher, I don't need extream and don't plan on running a induction cooker.
Been told there is room on the left near the 12v outlet, after having this panel out its mind boggling how much room there could have been.
I will eventually upgrade the factory battery to lithium or sodium and move to redarc 50 dc to dc but for now that part of the system can stay.
There is room on the sides with drawers or a draw/fridge installed - depending on inverter dimensions.
Which state are you in? ORS in Sydney can do customs fittings of the drawers or drawer/fridge. They did exactly that on my nephew's Patrol to get a battery box in on the driver's side of the drawers.
You could also do a custom bracket and mount the inverter higher, a bit like what I did with the air compressor (see below). That bracket is mounted to the side tie down points of the IG. You can re-attach the tie down point instead. The bracket also gives me storage between the bracket and the window. I had a second board installed on the other side.
I also mounted the L track on top of the drawers.
My drawers:
The drawer can be higher than the fridge, as I have seen slide out work area or tool drawers under the fridge to match the fridge/slide with the drawer height.
You can also remount the L track on top of the drawer/fridge, as their is a top plate on the ORS system.
ORS do custom so I got exactly what I needed.
Im after the area to be a open as possible so just the fridge height and draw next to it. Im getting a quote now with ORS, looking into options.
Where is the water tank located?
I'd like the L track to be in the top on not it, if its possible.
You can see part of the water below the bed extension on the left. Next to the rear of the drawers. Mine is a two seater. ORS can place the water tank behind the seats in a five seater, but the PAK Offroad water tank would be better for a 5 seater if you want to save space in the back. It goes in the rear footwell.
PAK Offroad Footwell Tank
Definitely the cheaper option when solo or 2 people, but as a permanent thing the kids 17 and 15 will not want there knees around there ears for long trips lol. Thinking water jerry on the back door and one side might be a easy solution, quick to remove when not in use, still 1300 plus for ladder to hold just 1 jerry seems extreme...handy but premium.
