Americas Interesting Steering / Adjustment Post from Owl Vans Engineering
terdrocket
10:41 AM
N. Florida
I’ve driven close to 3k miles in my Grenadier with about 95% of it on the highway. My speed has been anywhere from 55-85 mph and I have not had any issues with the steering. I actually prefer the steering as is and appreciate the “manualness” of the driving experience in the Grenadier.
This is where I am. 2500 miles in and it always tracks straight as an arrow no matter the speed. Minimal steering input is required. My steering is tight and almost manual feeling at low speeds, parking lots, etc.
Offroad
9:41 AM
Nashville, TN USA
I believe the manual suggests an unladen pressure of 36-37psi...
Brian ( @GooseGear ) found the Grenadier to have almost 50/50 weight distribution, so divide your curb weight by 4 and that's the load each tire carries static, of course, this will change as you drive/turn/etc and weight transfers; but will give you an idea of pressures to start with. Beyond this you can also do the chalk test (using chalk, stripe the tread, then drive forward/back and see where chalk is missing, adjust accordingly up or down).
Curious, is the 38 psi cold or hot? Thx
anand
10:41 AM
Maryland
Cold, always base actual pressures off of "cold" before driving; there are so many factors that can alter tire temps (road surface, road temp, ambient temp, wind, turning, etc) that then directly can change each tire's pressure independently making hot pressures more or less useless in terms of actually defining a baseline
anand
10:41 AM
Maryland
It would have been nice if he showed how much caster his Grenadier was running when he initially put it on the rack. If the factory alignment specification is 2 degrees, I don't see how this is a "free upgrade". They just set the caster correctly.
I appreciate that Owl is trying to make a name for themselves in the Grenadier community by making helpful recommendations, but I don't see "make sure your car is aligned to factory specs" as groundbreaking.
Also, it is not a free upgrade when you are paying a shop for an alignment. Whether or not adjustments take place, there is still the time to get the vehicle on the rack, place the wheel sensors, etc; the vast majority of shops would still charge some amount of labor for that, even if you get it on there and realize you're already at the factory set 2° of caster and don't need to change anything.
Tom109
10:41 AM
Isn't Owl the same guy that said our hinges were all wrong (happily offering a solution looking for a problem) ?
Shaky
10:41 AM
I assume this has been covered elsewhere, but unladen / lightly laden are you talking 38/40 or 40/40 or lower? I used to run the 200 series at 40 front and back day to day.
I’ll be doing 2000km mostly highway in the first few days of ownership so I’d like to get it sorted early.
I run mine which is essentially unladen, and I mean 1 or 2 passengers and 2 dogs at about 13kg each, at 36psi all round (cold pressure).
It was set at 42psi when I picked it up and I thought it was horrible. 36 is much more acceptable.
I will say that if I could change one thing it would be to have rack and pinion steering on it, my driving is 80% on road though.
I may in time see what companies come up with to improve steering but it’s not a real issue as it stands.
NoMoTaco
Global Grenadier 0742
10:41 AM
New York, USA
It funny that this came out/was posted yesterday, as I was simultaneously hanging in my local shop yesterday for the new tires to be installed and to get an alignment (Not because of the new tires obviously, but because many members have mentioned these vehicles coming from the factory slightly out of spec). They also centered my steering wheel as it was notched slightly to the left when driving straight down the road (But I feel the crown of the road may have been contributing)
I did not take a picture of the alignment machine screen, but these were my pre and post alignment specs:
Pre Alignment
Camber: -0.5 (L) & -0.5 (R)
Caster: +1.2 (L) & +1.5 (R)
Toe: +0.28 (L) & +0.12 (R)
Post Alignment
Caster: +2.0 (L) & +2.0 (R)
Toe: +0.10(L) & +0.11 (R)
There wasn't much of a discernible difference in the driving experience (albeit I only had 200 miles under my belt with the factory alignment and KO2s) My steering/handling experience has largely mirrored others in that there is a minor "Dead spot" in the center while driving straight, mine does not wander at speed but minor corrections are required with road undulations, and there is always a bit of an anticipatory component to navigating turns at speed on winding roads. No complaints here, very happy customer thus far.
Norb-TX
9:41 AM
Houston
Have driven 2500 miles so far. At first the car was pulling hard to the left on the highway (over 60). Adjustments were made and things improved - now at highway speeds while coasting the car drives straight. If I accelerate it darts hard to the left.
Mine does the same. Power on it pulls to the left, power off, goes down straight. It's frustrating but I'm only at 200 miles. I'll call Mossy and see what they say about it.
[ Adam ]
10:41 AM
Fairfax, VA, USA
Yeah - that's odd. I'd start with a check of the alignment.
terdrocket
10:41 AM
N. Florida
Definitely alignment issue. Had the same issue on my LC200 after new shocks and a crap alignment from 4wheel parts. On throttle pull one direction, on brake dive in opposite direction.
Global Grenadier 0076
10:41 AM
Netflix Balance GIF by Blown Away
donnygreygrenadier
10:41 AM
Agreed (not free), BMW alignment “specials” are in the $300 range - I can only imagine what Ineos will be.
[ Adam ]
10:41 AM
Fairfax, VA, USA
Korg
10:41 PM
Recommend a wheel alignment and make sure to get the caster set to factory spec. Mine was "out" and horible, now happy with it.
Offroad
9:41 AM
Nashville, TN USA
Send the bill to your dealer. Unacceptable in my opinion.
Catpaw4x4
GG 4101
10:41 AM
Virginia, USA
Pre Alignment
Post Alignment
Yep steering wheel a notch (~ 1") to the left - also equal free play.
