Inexpensive rear door table $88
I think the EOIS brand has changed the design of the table. The one I received has large square cutouts on the left and right sides where mounting holes need to be. I'm going to order the Vevor brand next and see what that one looks like. Anyone have a similar experience? Here's a link to my next attempt. Vevor table
Anyone with the Frontrunner tailgate table?
Can you confirm:
1. If you also have the FR storage system with boxes, the table fits?
2. With the table installed, do you have access to the plastic panel with the first aid kit / storage space?
3. Is there any drilling required?
Thanks
Can you confirm:
Thanks
FYI @bigleonski I have an open ticket with Dometic AU that covers your question 1. I'll share their response.
Thanks - if so, I’ll press the go button.
By my measurements if the 66mm depth is from the recessed part (outer edge) of the plastic door cover it will be ok. If it’s measured from the “door” part of the cover, it’s cutting it very fine.
I received the Vevor table the other day. It looks like the original EOIS table that didn't have the large square cutouts like the current one does. Bonus it was only $57 dollars. It doesn't come with all the extra parts that the EIOS comes with and the quality might be a shade lower, but I'll use it for now. attached are side by side pics.
