I'm confused
chrsbe
6:32 PM
Sternwartestraße, Wien, Österreich
Who has dug deep into the fuse box under the ignition key? I need your help.
My Wolfbox is currently connected to fuse FC23 using a piggyback fuse tap. When the PWR switch in the overhead switch panel is turned on, the Wolfbox powers up as well. I would like to change this so that it only receives power when the ignition key is turned on.
Which fuse should I use instead?
Merci beaucoup
C
I'll insert a file note that the cockpit fuses can vary slightly according to the distribution region. The layout might also vary with the MY so refer to your fuse card as the primary source of information.
This is the fuse card for my AU delivered MY23:
- The blacked out fuse number positions are not wired.
- FC10 is omitted (no e-call).
- Positions FC18 to FC23 are accessories fuses (power with key on).
- Positions FC10 to FC17 are live fuses.
I'm using FC12 (head unit) and FC23 (rear 12v outlet). My Wolfbox also comes on with the PWR switch because the rear 12v outlet is active with the PWR switch on. I push the power button on the bottom of the mirror to turn it off.
