Who has dug deep into the fuse box under the ignition key? I need your help.
My Wolfbox is currently connected to fuse FC23 using a piggyback fuse tap. When the PWR switch in the overhead switch panel is turned on, the Wolfbox powers up as well. I would like to change this so that it only receives power when the ignition key is turned on.
Which fuse should I use instead?
Merci beaucoup
C
Merci beaucoup
C
