How many radiators ?
Leonidas
12:52 PM
I have lost count of all the radiators in our Grenadiers
Main radiator in Front (for engine ) with fan 1 motor
Radiator-font bumper left (t case?) non-assisted?
Radiator front bumper right (gearbox?) non-assisted?
Heat exchanger behind the front left wheel (charge air cooling)- with fan
Engine oil cooler (on engine oil filter ) non-assisted
Have I missed something ? Is the above right ?
Main radiator in Front (for engine) with fan 1 motor
Yes
Radiator-front bumper left (t case?) non-assisted?
Transfer case oil cooler (RHD ROW)
Engine auxiliary radiator. Has a noisy fan that no one likes. (RHD ROW)
Item 12 below. B58 shown. B57 is the same.
Not sure what you're looking at there. The engine charge air cooler (intercooler) is behind the grill and mounted above the main radiator.
Are the transfer case cooler and the engine auxiliary radiator swapped around for LHD vehicles?
Yes
The A/C liquid heat exchanger on the left side of the engine near the washer reservoir cap
The transmission cooler. Stacked below the engine oil cooler.
What an enlightening, crystal clear, response!
Congratulations and ...many thanks !
PS : do you know if gearbox oil and t case oil are sent to their respective coolers/radiators by a pump or simply by temperature gradient?
You're welcome.
I expect the transmission cooler circuit comes off a main pressure gallery downstream of the pump.
The transfer case is an Ineos design and is built by Tremec in Mexico so it's a bit of an unknown. At a guess, I'd say there is a small impeller pump that creates internal oil pressure to distribute oil to the upper gears, bearings and shafts. This is likely used to create the positive oil flow to the cooler. The only visible electrical connections are the temperature sensor for the offroad page and the selector position feedback sensor for the high-low range, so I don't think there is an inline electric pump in the cooler circuit. Pure guesswork because I have not seen an internal schematic for this unit. Someone will hopefully chime in if they have better info.
Edit: Corrected the electrical connections.
You're welcome.
The transfer case is an Ineos design and is built by Tremec in Mexico so it's a bit of an unknown. At a guess, I'd say there is a small impeller pump that creates internal oil pressure to distribute oil to the upper gears, bearings and shafts. This is likely used to create the positive oil flow to the cooler. The only electrical connection is the temperature sensor for the offroad page so I don't think there is an inline electric pump in the cooler circuit. Pure guesswork because I have not seen an internal schematic for this unit. Someone will hopefully chime in if they have better info.
Again , many thanks for your- precious -response
You're welcome.
This is the only picture I have of the transfer case oil circuit. According to my dealer, the transfer case should be filled with 1.8 liters of oil. The entire circuit should have 3.2 liters !!! This contradicts the Ineos Quick Reference Guide, which states that the entire circuit should have 2.6 liters of oil.
Amazing the wealth of knowledge you guys have !
The radiator on the LHD, driver's side front bumper cools? Transfer Case or Engine Auxiliary Radiator ?
j3t3r, I was under the impression that the radiator and fan shown in the manual image for the T-case Greasemonkey posted was on the passenger side in the LHD models. I know I've been under the vehicle and had my hands on that damn fan that makes the truck sound like Airwolf. I resisted the urge to unplug the fan, and drive in silence while staring at the Temp sensor page in the Offroad menu.
Is't the intercooler in the inlet manifold on top of the engine.
That's a great question @CountyV8 and one I have been trying to clarify for a while. I have answered this previously but I now think I was wrong after studying the newly available workshop manual, parts catalog and description and operation docs in the portal today.
B57 Diesel.
1. My 2023 ROW B57 diesel has a front mounted air-to-air Charge Air Cooler (CAC).
2. The IA docs include a front mounted air-to-air CAC on diesel Grenadier.
3. The 2018 B57 US market training manual shows a front CAC for BMW vehicles. Importantly, there is no mention of a liquid-to-air CAC in the inlet manifold of the B57 (as of the 2018 publication date).
B58 Petrol.
1. Several references on the forum to a front mounted CAC on NA delivered Grenadiers. I (bravely) presumed earlier that this was accurate and I had nothing to physically verify otherwise.
2. The IA description and operation doc talks about a water-to-air CAC (WACAC) built into the inlet manifold on petrol Grenadiers.
3. The IA parts catalog does not show a front mount CAC for petrol Grenadier.
4. The 2018 B58 US market training manual shows a liquid-to-air CAC in the inlet manifold of the B58.
Score:
B57 Grenadier - front mount air-to-air CAC. No liquid-to-air CAC in the inlet manifold.
B58 Grenadier - liquid-to-air CAC in the inlet manifold. No front mount air-to-air CAC.
Anyone got something different?
I'm trying to figure what this little radiator does. I dinged the bumper and now I am trying to figure out if the engine overheating Im experiencing is coming from some congested airflow via this radiator on LHD Grenadier.
To the best of my knowledge the two wing radiators are the same for LHD and RHD. When viewed from the driver's seat looking forwards the left side is the transfer case oil cooler and the right side is the engine auxiliary radiator. Easy to check. The transfer case oil cooler is plumbed with steel tubing that runs rearward along the chassis rail. It does not have an electric fan behind it.
The auxiliary radiator is plumbed with rubber hoses of approx 9/16" (14mm) ID. The hoses run towards the radiator. It has an electric fan.
Your pic appears to be the left side (driver side for LHD) which makes the matrix the transfer case oil cooler, but confirm if it has steel tubes and no fan.
