Hi guys- looking for advice
4:22 PM
Australia
Hi guys I’m Matt a farmer from Australia,
I’m very close to buying a grenadier and looking for some advice before I dive in.
I know all cars have issues but are the ones with the Ineos more electrical, cosmetic or engine/running gear.
I need something reliable and I hear great and bad things. I love the look as I’m a defender lover. The shape is just so appealing to me and I’m sure all of you!
But is this a forever car or a 100,000km car?
No one knows yet. It's a new company. You're a farmer, so, If you had money for one tractor and you couldn't screw up the purchase, had to have reliability and spot on factory service, would you buy a (Deere, Farmall, Massey, etc) or from a new company, first time, first gen, first model Ineos? Farmers have favorites, but only Jeremy Clarkson money lets them be sentimental.
Hi @Matt- I've owned my Grenadier since the beginning of 2023, have over 30k kilometres on the clock now and am very happy with the vehicle. My vehicle has had hardly any problems from the start. Peeling door seals, water dripping in the footwell and heating/air conditioning irregularities were quickly rectified. I can't remember when I had the last problem. But I was also hesitant at first about what I was getting into.
Originally, I wanted to use the vehicle exclusively for agricultural purposes and apply for a special licence plate (a green number in Germany). I wanted to continue driving my Land Rover in everyday life. Today I have moved on. The Grenadier is my work tool, daily driver and best mate. I sold some of my Land Rovers, which I loved very much, for very good money and the Grenadier accompanies me everywhere. I have no regrets about the purchase. There are also bad opinions about the vehicle here. I think that depends very much on the expectations of each individual.
I am also well looked after by LeTech, my dealer. That certainly also plays a big role.
So far, I've been able to go wherever the John Deeres have gone. With one exception. The ruts were too deep. But that's not the Grenadier's fault.
We don’t do politics or religion here but we might need to add tractor brands to topics to avoid! I imagine those passions run deep 🤣
Longevity is hard to say until we get there. However, lets look at what we know.
  • Ineos has less OEM than most vehicles. It utilises numerous third-party manufacturers for components that enthusiasts and professionals add to their vehicles after purchase. That is in part why the Grenadier is more expensive.
  • The body is solid and that is clear for all to see.
  • The B57/B58 engines have good reliability, and the Ineos version is tuned differently for reliability and torque. The B57/B58 engines have gone through 100k easily enough on BMWs but . We don't know how the IG version is going to last. Detuning it should help. However, the engine is dealing with much heavier vehicles and more extreme angles and vibration.
The vehicle is now in its third year of manufacturing, and early faults and issues that were seen on MY22 & MY23 have seen most ironed out with MY23.5 and MY24 and the current MY25. However, some persist.
  • Software has come a long way across the model years, but it can still be prone to throwing up false positive fault warnings that will not be there on the next restart. The newer software versions have very few issues in that respect. However, Ineos forked the software with MY24, and some of the fixes seen on the software fork for the MY24 have not been applied to the MY23.5 or earlier.
  • HVAC - this is probably the most common issue but most have found that delaying the start by a few seconds to allow the HVAC to cycle through its startup avoids the issue. Some have found their reservoirs needed filling, and that fixes it.
  • There are some minor common issues, but they don't affect everyone but that is probably no different to any car.
We are on a farm. Although it's equestrian nowadays. The Grenadier replaced a 2015 Defender (last of the line). We have four tractors. The Grenadier tows the horse trailers; it pulls the muck trailers into sloppy clay fields in winter. It goes down farm tracks which are often very rutted from the tractors. We use it to pick up the feeds and bedding.
We are coming up to the first year of ownership and issues in that first year have been: Rear parking sensor failed (nearest one sticks on if you are in reverse) - that issue has been repeated with some other owners but fixed with replacement sensors. A heating valve flaps when it's very cold and the heating is working very hard (but not at any other time). This issue again has happened with several others and ironically, with one of our dealers' quartermaster. That is still waiting for sign-off for a fix from Ineos. A cracked windscreen - lots of reports of cracked windscreens and they do seem to crack in the same place. However, my windscreen repairer said that vehicles with no seals on their windscreen often suffer more cracks, as it exposes the weak spot of a window to impacts (i.e., a stone thrown up bounces across the bonnet and then is fired upwards into the outer edge of the windscreen). It also has aircon condensation leaking on passenger side. A known issue that is fixed on newer builds but there is a TSB to fix it on older builds (which is to lag the pipe so it doesn't condensate). That will be done at the next service on mine.
I delayed my purchase of the Grenadier as it didn't want a first or second year version as there is a risk of being an early adopter. I had a year one Audi once and it was in the dealer over 15 times in the first year. So, I waited for year three before getting mine.
It does what I need it to do on my equestrian farm. I don't know what you will need it for on yours. What we have found is that we use it quite frequently for daily purposes. Much more than I expected I would. Its 3pm UK time as I post this, and this morning it took the dogs to dog training, then picked up some bedding and feeds. After lunch, it towed the 3.5t muck trailer to the current muck field down summer clay rutted tracks, and it's currently out with my wife using it on the supermarket run. I only expected to do towing and picking up bedding/feeds and the rest of the time sit there. It's proven to be more versatile as a daily driver than I thought.
You will get all sorts of answers on here. Some will tell it is perfect and some will say it is biggest heap of junk ever made.
I can only say from personal experience that mine after 20k Kms feels and drives like new. I did have the steering column and door seals replaced early on. (it was about the 2,000 built).
I have every expectation that it will last a very long time, but as above only time will tell.
My opinion, for what it is worth, is that maintenance is a huge factor. Treat cars like consumables and that is what they become. Look after them and they will last forever.
I previously had 2 Navaras, well known for issues. One I put 250k miles and the other 200k, both running really well when I sold them on. Things like regular fluid changes, checking hoses, belts, bearings etc take little time but will make such a difference. Sorry, went off topic there.
I've had my Grenadier since March 2025, and put a little over 3,500 miles on it. I've had no issues with it so far, but it's a small sample size. The truck feels very well-made.
We used Ford/New Holland. Before I shit the bed, I'll have a reason to buy a 9N.
That was an optimistic statement. They Ignored everyone for 2.95 years and have just begun to address issues.
I bought mine in March 2024 and now have 17k miles (27k km). Had initial HVAC problems, resolved early by dealer. We have snow 5 months of the year here and I am never stuck. Daily drive to town involves 1,400’ elevation drop and return up 8% grade. DIY Oil changes are easy and I do them at 4k miles or a minimum of twice a year. Software issues and inability of owner to reset maintenance reminders are minor nuisances. I keep track of maintenance with written log entries like my plane. It’s built like a tank and I intend to keep it forever.
I have over 70,000km on mine. I work in forestry, it gets used, if you know what I mean. Mechanically I think it's great. my one question would be the electronics. To me fair mine has been fine so far. I have had some glitches in the head unit and spurious error messages which have never stopped me going anywhere. Things have been ok since the last software update. I had a turbo hose fail recently, thats the only mechanical issue (that wasn't caused by me).
I'd say its more reliable than the old defender, Ive had 3 of those and put around 300,000km on each one...
Hopefully you get one with a less noisy Power Steering pump.
Hi Matt , James for the Uk I have done 6500 miles in my 2 seater and I have loved ever minute of it and the best bit is it hasn’t even been but to the dealership since I bought it. I am I Defender lover as well and this vehicle is the real replacement. My advice is to buy it!
Good luck James
You’d think when I go to dealer and ask has this car been checked over for for all the above. Surely those things are ironed out by now!
  • Haha
Reactions: CRH
You make some strong points
Yeah it would be my everyday farm car. I’m not that far from a dealer, about 40kms away and my local mechanic is a wizard so if need be he’d able to patch the odd item here and there without messing with warranty. It’s a box on wheels, the electrical don’t bother me because they are an easy fix and I can live without them, it’s more running gear and engine stuff that concerns me
Can you define older models and new models for me please. Is 24-25 models that seem to be more sound?
Matt… I think the HVAC, door lock recall, and software update are all ironed out and should be done prior to delivery for any new vehicle but ask just to be sure. Trust but verify.
