Henry's Blog
When you cave in and permanently mount it, look here:
STARLINK CARRY BAGS
  1. KELMATT bag to carry Starlink Kit here;
  2. Blacksmith Camping Supplies' Starlink Mini carry bag here;
  3. Underkover Starlink carry bags here;
  4. NAVIGATOR’S Starlink Buddy and TV Transit Buddy (for different Starlink models); and
  5. DRIFTA Starlink Gen 2 Satellite Carry Bag, look here.
STARLINK MINI BRACKETS/MOUNTS
  1. SVNTY Starlink Mini Mounts here;
  2. Outback Comms vehicle mount here;
  3. DV Mechanics here;
  4. BA Starlink Mini mount here;
  5. KAON Starlink mounts here;
  6. Pirate Camp Co Starlink Mini Quick Release mount and bracket here;
  7. Starshield Mini Mounts here;
  8. SCRUB KING Starlink Mount here;
  9. Smart Touring Systems Starlink MIni Mount (key lockable) here, demo video here;
  10. All Terrain Action has a large selection of Starlink products here;
  11. Outcamp Starlink mounts here; and
  12. Dishy Mini Mounts here (and lots of other Starlink stuff).
That won’t be happening. I need portability for field trips when I fly to remote sites and work out of client vehicles. Plus loaning it to family for their trips.
You can add the 12v shop to the your list though. They have become my local go to shop for 12v bits n bobs.
Cheers
Steve
Cheers
Steve
This one will do nicely: Smart Touring Systems Starlink MIni Mount (key lockable) here, demo video here.
Easy in and easy out.
View: https://youtu.be/8KbA0GRqFCI
Nice and I liked some of his comments particularly about sat phones in the video,
But portability for me also includes the mount so their mount doesn't fit my use case. I can fit the terminal (in a neoprene sleeve), mount, cables and charger into a small conference satchel with a total weight of only 4kg. This can be thrown into my check-in or as taken as carry-on. At the other end I can set it up on a client vehicle and be connected in a couple of minutes.
Also remember I'm a minimalist when it comes to kitting out vehicles. Weight is one enemy of reliability. It will take me an extra hour to 2 to pack and unpack for trips away, but after over 40 years I'm used to that.
Cheers
Steve
Fuel Transfer Pump
A bit of recycling from the garage junk pile.
I’m finding that lifting jerry cans and juggling spouts into the filler is becoming awkward so had already started looking at 12v pumps.
While cleaning out the garage the other month I came across an old 12v shower I made up many years ago when I had a caravan. It had a small submersible/inline pump (Rule il280p) that could fit into square 20l poly drum and plugged into a cigarette lighter socket.
Looking at the pump instruction manual I found it was also rated for pumping diesel fuel so I modified it to act as a fuel transfer pump. If the fuel container has a 58mm cap the pump will drop straight in, but for a standard metal jerry can the opening is too small. To work around this the white shroud at the bottom can be unclipped to expose a hose barb where a short length of hose can be attached so it can be used with metal jerry cans. I also put an old juggler fitting on the inlet hose end to help with priming the pump. All bits came out of the garage junk pile so total cost was $0 for a change,
I also found that a 20mm PCV pipe joiner was exactly the right diameter to open the damm fuel flap. I glued 2 joiners onto a small length of pipe to make a sleeve that filler hose can pass through. Once the hose is inserted in the filler I can pull back the sleeve.
The pump is powered from the 12v roof outlet and only takes a couple of minutes to drain a jerry can. When not in use I have it stored in an old plastic sheet bag with a towelling rag to wipe it down so it doesn’t stink the car out.
Old School Jerry Can
Wide mouth Jerry Can
Cheers
Steve
Fuel Transfer Pump
Looking at the pump instruction manual I found it was also rated for pumping diesel fuel so I modified it to act as a fuel transfer pump. If the fuel container has a 58mm cap the pump will drop straight in, but for a standard metal jerry can the opening is too small. To work around this the white shroud at the bottom can be unclipped to expose a hose barb and I can fit a short length of hose so it can be used with metal jerry cans. I also put an old juggler fitting on the inlet hose end to help with priming the pump.
I also found that a 20mm PCV pipe joiner was exactly the right diameter to open the damm fuel flap. I glued 2 joiners onto a small length of pipe to make a sleeve that filler hose can pass through. When the hose is inserted in the filler I can pull back the sleeve.
Cheers
Steve
I used 19mm fuel hose for a siphon and that fits perfectly for the filler, I did consider a 12v sub pump after siphoning 80lts out of 4 plastic cans....very messy. Great idea @Rok_Dr 💡
Another Sticker
A little bit of self-promotion and recreating a similar sticker I had on my old discovery from the AULRO Forum.
A sticker supplier on eBay did the Rok_Dr text for $4 inc postage, while the Global Grenadier sticker was a freeby with the metal badge.
Looks pretty neat I think.
Cheers
Steve
Thanks @MrMike I hadn't thought about 19mm fuel hose a good idea!
Fuel Transfer Pump
Looking at the pump instruction manual I found it was also rated for pumping diesel fuel so I modified it to act as a fuel transfer pump. If the fuel container has a 58mm cap the pump will drop straight in, but for a standard metal jerry can the opening is too small. To work around this the white shroud at the bottom can be unclipped to expose a hose barb and I can fit a short length of hose so it can be used with metal jerry cans. I also put an old juggler fitting on the inlet hose end to help with priming the pump. All bits came out of the garage junk pile so total cost was $0 for a change,
Cheers
Steve
I like repurposing stuff. Thanks for sharing.
I put my fuel pump in a cheap dry bag. No smell and no leakage.
If I take Jerry cans I would take my Tanami pump. The Tamami uses air from the air compressor and has no moving parts. There are petrol and diesel models of the pump.
Drivers Grab Handle
I managed to pick up a driver’s side grab handle kit at a good price from a local chap who cancelled his Grenadier order. The kit came with the side pillar trim, handle, bolts and handle bolt caps. Easy to fit, and the online workshop manual illustrated how to disengage the hidden clip on the existing panel.
Part numbers for those who are interested:
Now to relearn my entry and exit technique 😊
Cheers
Steve
I've fitted the BD 68L aux. tank. However, for a planned Simpson desert trip in July, I also have several Scepter "squat" shape 20L poly jerry cans. The squat shape makes them more stable on a roof rack, and quite manageable even for this almost octogenarian 💪. Coupled with their excellent sealing and breather, and the expanded "high fill" throat of the BD inlet, it's a simple task to quickly and efficiently decant diesel without "wearing" the contents.
For Aus. owners, Repco currently have them on catalogue sale for A$31.50 (normally A$42)
Another Sticker
A sticker supplier on eBay did the Rok_Dr text for $4 inc postage, while the Global Grenadier sticker was a freeby with the metal badge.View attachment 7914347
Cheers
Steve
Pretty sure our Aulro ones are still on the discovery and defender we have... 5teve on one side and dont do scratches (missus) on the other :D I'm that used to seing them I cant tell you if they actually are still there or not!
