I had that exact model in white with the 3.6lt in itNothing to do with Henry, but I thought I’d share a pic of his garage companion, Lady Penelope all ribboned up for my son’s wedding last week.
Steve
Hi there. Did you get this resolved? If so, how? Fingers crossed. Drives me bonkersHi there. You say your dealer managed to mitigate the 1800-2000rpm resonance. Do you know what they did? Like many others, my diesel trial aster suffers the same problem and desperate to get it sorted. Thanks.
Yes I did reply to you see post #94 in this thread on the 22 DecemberHi there. Did you get this resolved? If so, how? Fingers crossed. Drives me bonkers
 . For the sandgropers here it would be a good spot for a Grenadier meetup.
. For the sandgropers here it would be a good spot for a Grenadier meetup. . Now that it's installed and having a 1400km range with a 50km+ reserve (admittedly highway touring, lightly loaded) I wouldn't be without it! Sydney to Brisbane last week via the Pacific Hwy was a breeze!
This was the very first item I added to mine and purchased from the forum shop. Cost a fortune to get to the UK, but worth it, and it supports the forum. I have also added a light on the ladder for reversing when it's dark using one of the exterior electric so sockets, just flick the switch when needed.Number Plate Light Shields
Finally after over 6 months patiently waiting, my son printed me a set of number plate light shields.
He also did a very rough draft print of a tow hitch cover with the V embossed in the surface. It looks ok from a couple of metres though. I had to paint both in flat black as he only had grey filament. The V is painted in Alfa Rosso as I had a can in the garage for the Alfa
As the before and after shots illustrate the shields make a perceptible difference particularly closer to the car.
BEFORE
View attachment 7890284 View attachment 7890286
AFTER
View attachment 7890287View attachment 7890288
Steve
Yes, I am interested in that for water storage as I have the fuel sorted.Next adding a small amount of extra fuel capacity.
I’ve been looking at extra fuel storage and rather liked Black Sheep’s spare wheel mounting bracket and round overland fuel cannister solution. Unfortunately, Black Sheep’s Australian agent didn’t stock either and it was a bit too expensive purchasing direct from Europe.
With a little googling I found a round overland fuel canister and mount on ebay, both at a reasonable price.
For the actual bracket, GP factor in the US made a similar bracket to Black Sheep at a cheaper price (https://gp-factor.com/en-au/collect...cts/grenadier-spare-tire-rotopax-mounting-kit)
No problems fitting the overland mount to the GP factor bracket and my spare wheel cover neatly hides the mounted fuel can as well.
I’m still tempted to get a Letech ladder though…..
Steve
Have just been to Stirling Ranges with my trialmaster and Tvan. Very impressive place. Also just been through Helena and Aurora park follow your comments in an earlier post. Absolutely loved it and Gus ( grenadier) and Tom (Tvan) revelled in it. Thanks for postingTime for a bit of catching up.
Firstly back in April I spent a week at the Stirling ranges, staying at the Mt Trio Bush Camp (https://mttrio.com.au/) with some members of the WA Land Rover Club.
I really liked the camp ground. Plenty of room if you only need an unpowered site and views of the Stirling ranges from the top camping area were pretty awesome. The communal areas were also very nice and on the weekend they had live entertainment. From where I was camped it was a bit of a walk to the camp kitchen and showers, however there were plenty of porta loos spread around the camp ground for those midnight visits. For the sandgropers here it would be a good spot for a Grenadier meetup.
The only decent 4wding I did was a day spent around Cheynes beach on the sand tracks and beach. Managed to get Henry bogged for the first time but a few minutes digging and 2 maxtraxs solved the problem. Memo to self…. put the diff locks in before you get bogged.
Campsite with views of the Stirlings.
Mt Trio Bush Camp Kitchen facilities.
Granite outcrops Cheynes Beach
Cheynes Beach
Steve
Nice work SteveRear Ladder Jerry Can Holder
I really lust after the Letech rear ladder jerry can holder, but at over $2k AUD delivered I can’t justify buying one. Looking at other options on line gave me the idea that perhaps I could modify an off the shelf holder to mount on the rear ladder.
So the following is my first effort. All up about $60 and a couple of hours tinkering. I can easily get to the door handle and I'm pleased that it clears the rear light assembly when the door is opened. It also feels solid and robust, but time will tell…...
Shopping list:
The clamp brackets I bought didn’t have inserts for the 25mm steps on the ladder, but using one half of the supplied insert and some rubber strip enabled them to clamp securely. For the 30mm ladder bottom a couple of turns of insulation tape were sufficient for the clamp to grip securely. Using the 25mm aluminium strip I made a short extension L bracket for the bottom clamp, to allow the holder to sit vertically.
- Basic Jerry can holder from Supercheap/BCF: https://www.supercheapauto.com.au/p...XUa3tNDmCYd573d-nRU5pJ6aqmmaJv5qAsjlk04U09qMI
- Pipe Clamp Light Bar Mounts (19-30mm) from ebay. https://www.ebay.com.au/itm/1551087...pid=5338980679&customid=&toolid=10001&mkevt=1
- Dome head, 25 and 20mm M8 Bolts from Bunnings.
- 25mm aluminium strip left over from the fire extinguisher bracket and some scrap rubber strip for padding.
I had to drill some extra 8mm holes in the holder as the pre-drilled ones didn’t line up and used dome head bolts to mitigate any possible rubbing. The final touch will be to glue some padding strips on , but I need the rain to stop first
Steve
I had the same experience, but now it doesn't do it. Glad you resolved that sinking feelingSubsiding Seat
For a while I’ve had a slowly subsiding driver’s seat which dropped over 2-300km of driving to the bottom setting. After a number of trips to the dealer and a bit of testing, the problem was traced to my knocking the lever as I exited the car. Unfortunately, I have shortish legs so getting out is often a controlled crash/slide out of the car. To solve the problem, I removed the plastic finisher on the handle so it doesn’t protrude as much. Once I learn to exit more elegantly, I’ll refit it LOL.
Steve
