Heat and AC are both schizophrenic
10:19 PM
Nashville, TN, USA
I am having an odd issue that I haven't read about here yet. Maybe I missed a post. Tried searching but nothing lines up.
Have had my grenadier since June of 2025. Daily driver. Being in TN, with the changing temps like they have been, the problem has become more apparent.
If it is cold outside, I get heat blowing from every position on the temp dial except the coldest spot. And it isn't adjustable heat. It is scorching hot. To the point when it is in the second to lowest cold setting, 66 degrees, it is uncomfortably hot. I turn it down to the last notch, coldest setting, and it does shift to cold air. But it is freezing outside so I have to turn it back up one notch to scorching. Then when it is hot outside, the exact opposite happens. Blows freezing cold air on every setting except the hottest. I am turning the dial slowly and allowing it time to adjust, but there is really no change.
I dropped it off at the dealer last week and they had it and tested it for 2 days and came up with the fact that it responds just like their other inventory. I had a loaner for two days and I agree. It did the exact same crazy heat and cold response. The dealer said that's just the way it is. Seriously, that's the best you've got. They have a theory though. Because the car was designed in England it has a difficult time handling the temperate climate of TN/USA.
So for me, I have an SUV that I love but I am pretty sure I could go and buy a 2025 cheapest car on the market and the AC and heat would probably work. How can Ineos produce this vehicle and fail so miserably with the heat and AC? Just seems like a stupid aspect to fail so miserably. It is irritating on a daily basis.
The other thing it does when switching from hot to cold to stabilize temps in the cabin is it starts blowing really cold air in the footwell and hot air up top. What kind of crazy engineering is this?
Anybody else having a similar problem? Any ideas on a fix?
I have a brand new 2025 QM and it does the same thing. Sometimes setting it to auto helps but not always. Not sure what to do at the moment.
2024 Trialmaster does the same. Randomly will run fan of full blast (even when temp is not extreme) . Other times it will seem anemic.
I have no clue what causes this, but something tells me to start at the input dial (seems a bit cheap to me).
Annoying, but I didn't buy this expecting it to be a Lexus (although I know what you will all say..........its a $90k vehicle and even a base model Kia has proper HVAC)
Bottom line is that lots of little quirks of the Grenadier are not optimal and maybe there are fixes at some point, but I have had mine for 16 months and 10,000 miles and aside from the scheduled oil change, I have not been to see the dealer for a single unscheduled service or any downtime and that's a heck of a lot more than I can say for any of the other new Audis, Porsches, GMC Denalis etc I've wasted money on in the past 10-15 years.
I'll deal with quirks as long as they don't leave me questioning reliability.
I didn't buy it expecting it to be a Lexus either. But I really don't think a functional HVAC is an unreasonable expectation in any car in 2025. When the dial says 66 degrees, at least get the temp close. I have been meaning to take my infrared thermometer with me to record temps from the vent at different settings but never think about when heading out. I will set that out right now.
Check to see if both high and low coolant tanks are filled between min and max. If so, then run the bleed process, it's documented in here. If that doesn't work, take it back and ask for new valve system. My understanding is our system is a heat pump not your traditional car system. Could be wrong but thought I heard that we do on the warner fluid change video. Plus, BMW uses heat pumps on their ev and hybrids.
What I know with heat pump in my house, running cold and hot at same time, it will struggle when not in mild temp. I run auto in PNW in winter and the outside temp is between 40 and 60. Anything out of that range, I don't run auto. I run heat or a/c.
Common System Struggles for heat pumps.
Refrigerant Issues: Low refrigerant levels reduce heating/cooling capacity, making the unit work harder.
Reversing Valve Problems: A stuck valve prevents the unit from changing between heating and cooling.
Both of these is what seems to be our issues. The stick valve can be function of auto moving back and forth to quickly.
Both tanks are overfilled. Leaving town tomorrow for a week so will address that when I get back. Thanks for the guidance.
2024 US model. Air management was never exemplary, but it was somewhat linear between hot and cold with regards to temp output.
About 6 months ago it became random at best-full hot might mean full cold or vice versa. This vehicle was at the dealer for metal in the front diff fluid which I found when when I changed the fluid; the random hot/cold air problem, and recalls. In both case the dealer, Sierra Ineos Grenadier of Orange County CA (not where you want to take your vehicle for service), said there is nothing they could do and the car is fine. Fortunately with regards to the air mix when they brought me the car they had the air conditioning on and full cold on the control, and it was blowing hot air; they could no longer tell me nothing is wrong...
I have tickets opened with Ineos corporate on both defects and will post the outcome on the forum.
My 2025 Fieldmaster has a similar behaviour in the front. But the air in the backrow does work as you would expect it to work. Any Idea what could cause this difference between front and backrow?
Check and see if you have “auto” selected - for me, that seemed to reduce some of the wild swings
Interesting. My dealer told me never to use auto for the AC. Since I have been back in town, and it is below freezing everyday, I have used the auto some. What I find on mine is that to get the car up to temp, better not to use auto. It starts out very weak and takes too long to start blowing hot air. I switch auto off and then it starts kicking and heating things up better. Once it gets to a comfortable temp, I switch it back to auto and it seems to hold the temp well. Still doesn't function like a brand new vehicle HVAC should function but I guess it is acceptable for now. Maybe a fix is coming down the road but I doubt it. Maybe they change it on new models and I just have to live with it or buy a new one if they ever fix it.
I am terrified of the defrost mode with a cold windshield - it blows really hot air full force, and I (along with some others) think that might result in a cracking windshield - but yes, you’re right, it takes a while to come to temp, and you get this whole operatic ridiculousness where vents slowly come online and blender gates slowly get around to the idea of actually doing their job
Besides checking the 2 coolant tanks I have found that allowing the system to "boot up" before starting the engine helps.
Turn on the ignition and wait for everything to settle down. Fan usually comes on at this point and I start the engine.
I believe this extra step allows the system to read the internal and external temps as well as set the doors/flaps.
I agree, it literally only takes the time to fasten seatbelt for the whirring & fan to kick in.
OTOH the whole system is pretty 💩
Is the HVAC a BMW design? Do BMWs have these same quirks?
I’ve had 4 late model BMW’s and no HVAC quirks so I’m guessing not.
Try this, it seems to fix it for me... With the engine warmed up, turn the fan off, press AUTO, turn the temperature all the way up, drive around, so you get the RPMs up.. It is going to blow cold air for a few seconds, then you will hear flaps moving around and then hot air will come out. Let it blow for a couple of minutes, then turn the thermostat back down to a normal temperature. ..
I felt that I’ve been lucky so far and didn’t really have any major issues with the HVAC system. But today it was -30°C and I couldn’t get the heat to work at all and it wouldn’t even show up on the screen , fortunately that was at the end of the day and it wasn’t too much of an issue, but I’ll see if it resets in the morning.
Like not at all for a prolonged time, or do you just mean nothing happens right then? I’ve had similar weather this winter, but after a few minutes of driving, one by one you hear the gates flip and vents start to blow hot air. Even once it starts, the process takes a minute or two to fully engage and cycle all the way around (and then it’s way too hot) - and that’s AFTER a couple minutes of driving.
Defnitely NOT :) I had 7 BMWs in the last 17 years and none of them had an HVAC problem. Btw. my Grenadier's HVAC has no problems either. The Grenadier's isn't as smooth and comfortable as a BMW HVAC but not bad at all. I love the knobs and buttons and hate my i5's touch screen
