None at all, just recorded on the phone. As simple as that.Petrol, I guess?
Nice!
No acoustic tricks?
Thanks Steve sounds good just standard lets hear more of that . You must post that everywhere.None at all, just recorded on the phone. As simple as that.![]()
That was the petrol version.It does sound nice but is that petrol or diesel?
Sounds more like vehicle with far less ground clearance.. and wing-doors..
I should be a bit more precise:No acoustic tricks?
A lot of the turbo petrols now have a high idle (auto choke) on cold start. My mates Jeep JL 2.0 is loud on a cold start, but soon settles downSounds more like vehicle with far less ground clearance.. and wing-doors..
@emax I agree with you completely. I also bought an SLK230 compressor in the last century.Same with our 2008 SLK. Not a turbo, but a Kompressor. Plus the much higher revs before the automatic engages the next gear when the engine is cold.
Simply put, the software forces you to rev high when the engine is cold. I HATE IT!
I've been thinking about this, and I think I now know why: this is a quick way to get the emissions into a "better" range. Obviously, the necessary temperatures for a working catalytic converter and optimal combustion are achieved more quickly.
What looks like a sensible concept at first glance is actually a cheap way for the manufacturer to get away with better official exhaust values.
But the customer pays the bill in the end: with higher fuel consumption and greater engine wear. The concept is good for the numbers, but not for longevity.
It sucks!
www.instagram.com
Aaah - diesel music to my earsQuite a clear engine note on this video:
Login • Instagram
Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.www.instagram.com
Easier to turn the “volume off” via OBD11 or vagcom. That’s what I did to mine - along with many other little tricky things that VW try and hide from you.Vw golf r have a resonator on the windscreen that gives a more throaty sound in the cab first thing that gets removed with most .
Miss Piggy flying with a big smile on her face...and if that happens I then would declare that "Peace has broken out"...happy motoringGrenadier with wing doors.
What would it look like?![]()
