GP Factor *New* - Maxtrax & Rotopax Spare Tire Mounts from GP Factor
Good Morning Grenadier Fam!
We are excited to announce two new (of many to come) products for your Grenadier - Our Maxtrax Spare Tire Mount and Rotopax Spare Tire Mount. Both of these are a very easy install with no modification needed. You remove your Spare tire cover or storage box, bolt to the existing M8 holes using the factory Torx screw, adjust the brackets, and you are good to go! All orders will ship in roughly 2-3 weeks max. Ill do my best to answer any tech questions you have today asap.
Maxtrax Mount Specs:
- Our Propriotary latch that we have been selling for over 3 years that is proven, durable, lockable, and works with 2 maxtrax, 4 maxtrax, 2 regular with 2 extremes, or 2 extremes. We designed the latch this way so you can use whatever amount you want. If you own 2 and buy two more, this mount will still work 100%. It also works to attach in any of the handles on the Maxtrax. We have it high in the pictures for clearing the tire, but you can center it as well if you dont care about them showing up in your rear back up camera or departure angle. The latches also work with deformed, old, new or any state your maxtrax are in. They dont need to be "new" to work with our mount.
- The mounting bracket is adjustable and fully stainless. It will work with all factory wheel tire combos, and there is some adjustment to work with other wheels as well.
Rotopax Mount Specs:
Same bracket pieces as the Maxtrax Mount less a few riveted on parts. All stainless Construction and you can mount the rotopax Latch (not included) either vertically or horizontally. This will work with multiple tanks, typically 4 gallons (2 tanks or the long 4 gallon).
Links:
MAXTRAX:
ROTOPAX:
These are in stock and ready to ship from us and ok4wd.
Thanks!
AJ
Looks like the mounts accommodate a wider wheel/tire but could it be done with some offset to allow for larger diameter tires? I don't plan to upsize anytime soon but that will probably be done a lot.
It will work with a bigger tire for sure
I totally missed that it wasn't a whole replacement wheel mount. That's great. I currently have tred pros. Do you know if your mount is compatible with those?
It’s compatible with Maxtrax, maxtrax extremes, maxtrax lites (those just got released), and the mini maxtrax. So yeah it works with maxtrax. The new lites should be pretty popular. Half the price and about 2/3 the length of the regulars. We will
Post a pic with those mounted once we get a set.
@GPFACTOR your spare wheel offset, have you tested on the QM? Any size over 33 will not bolt to the tub. Thinking your offset will fix the problem.
We have not tested it to mounting these on a QM spare in the tub of the truck. I am not fully aware of how that bolts in the bed. It could work but I’m not 100% aware. Just depends how it bolts down. Our mount specifically bolts to the plate that is mounted to the station wagon spare tire.
I'll get pictures this weekend. There is a brace that bolts on to the tub. The brace then has the bolts for the tire. Might be the same one used on the station wagon.
@GPFACTOR - with no recovery boards mounted, does your bracket sit flush (or recessed) with the spare? Would like to still run my spare cover from RDS when I don't have recovery boards mounted. Thanks in advance!
I don’t think it will work as the spare cover has a plastic piece that gets removed when you use our mounts
Thanks for the response! This isn't my truck but same dealer so same cover, I wasn't talking about the OEM Ineos plastic insert, just this soft RDS (or similar) cover they use. It's purely cosmetic and fabric. Hoping maybe this would work?
