Front Fuse Panel
Brock63
8:54 PM
South Carolina , USA
Question? I am looking to patch into the front fuse box using a switched wire/fuse location...and was wondering if someone can confirm if the metal screw on left side is grounded...so can attach ground wire there and tap into a wire safely?
A picture would help. There are several screws in the area that can work as grounds.
Both are pics taken by @Loc Nar from his build thread. I just added the circles for ya
I used the ground in pic #2
That is exactly what was looking for....I could only see the black ones that mount fuse panel with cover off....I was thinking of the torx head one on left of one you circled...but the one you used is easy enough. Thanks a bunch.
Just an FYI...
Brock, if you have a multimeter, you can use the continuity feature to check/find a good ground...and confirm if any bolts are good grounds.
Connect to battery negative or a known ground source (Mayneed to use a pice of wire for na extension) and then to the item you are checking. A beep or very low resistance indicates a good ground.
