FLAC Files via USB-A thumb drive?
derek_zoolander
1:14 AM
USA
Hello all! First post! USA here and have owned my Scottish white trialmaster for about a month now. I seem to remember the manual specifying that the head unit supported FLAC for the USB audio device, but I cannot for the life of me figure out how to get the music to show up or be playable.
Is there a specific folder structure that is required for the music to be recognized?
In my testing the other year .flac format files were playable and artwork recognised. Thumb drives need to be formatted as either fat32 or ntfs. Size should be <32gb.
It will be slow to load if there are a lot of files as well.
I have almost 10k songs but have had it plugged in for multiple 2-3 hours drives. I'll check the formatting next, as I doubt it's ntfs as I have a Mac. Most likely exfat.
There's also some scattered mp3s there that aren't showing as well, so odds are being the formatting now that you mention.
May also just drop 1-2 songs on there first to test before wasting time transferring 10k.
Thanks rok_dr, away from the car for now but will report back when I can test with the results 🍻
I can confirm if it’s formatted exfat it won’t be recognised. Also when the drive is plugged in it should appear as a source in the audio menu (not greyed out) if recognised. Finally don’t use the usb outlets at the back of the rear console (if you have that option). They are for charging only and have no data capability.
Steve
Okay - so figured this out. Turns out the Grenadier does not like USB SD Card readers like this guy (which worked fine in my prior BMW). Using an actual USB stick worked. Kinda sucks because the appeal of the card reader is the extreme low profile nature of it and you dont have to worry about smashing it. Everything else Rok_Dr said regarding format seems to work as I've formatted to FAT32 and now my mp3s and FLACs are recognized, sans issue mentioned above.
Anyone have a USB SD Card reader that works with the Grenny?
Good to know that the ineos system doesn’t support sd cards.
On the plus side you shouldn’t have to look too hard to find an equally or more compact usb drive.
Steve
