Finally, my rubber Fender Plates !
Martin S
11:16 AM
BEL and NLD
YES, took a while to collect all material, but now I am the happy owner of (EU legal) rubber checkered fender plates !
These are made from 3mm EPDM rubber, suitable for outdoor and UV resistant.
I used 3M VHB tape primer before applying the 5952 double sided adhesive tape for a better bonding and it seems to work.
Anyway I have more material for an extra pair of fender plates if necessary.
They look really good and certainly are as good as those (illegal) Alu plates.
:):cool:
I'da rounded the tips. That point is a waiting for something to catch it, and its weak point for the adhesive making it easy to pull back.
Interesting, thanks Martin, I did not know the metal plates were illegal in BE. Where did you get the info?
Thanks
Laurent
Hi Laurent, I believe this is an EU-rule, but anyways I am not very keen in creating a horizontal guillotine in case one gets loose (during an accident for example) :)
At the moment it still fits, if not, I have ample material to make a new one. :) But somehow, I find the straight edges more pleasing, rounded one would look a bit off, no?
Hello Dalentino, it is 3mm EPDM rubber, suitable for outdoor and UV resistant :
Black Diamond Checker Plate Matting – Item Code: RC04188-3MM-1.5M.
Sourced them from the UK (RubberSmart) , they were kind enough to just send 1m and not the entire roll :).
I need to check. Mines hold in place with 8 metal rivets each, it should hold even in case of collision, it’s not like we can drive these very fast anyway!
