Failure to proceed
ScottishGrenadier
4:42 AM
Scottish Borders, UK
Grenadier momentarily refused to start this evening. Had been driving fine before I parked it up for 40 minutes or so but then just turned over without firing, sounded like an immobiliser issue. Locked it and left it a couple of times, after the 5th or 6th time it fired up and ran fine. I have experienced this once before with another Grenadier.
Anyone else had similar problems?
I’ve had it happen twice in 24,000 miles. Didn’t throw any codes but nothing - zip. Turned the key back off and waited a couple minutes - started after a couple of tries. Still have no idea what was happening. Wondering if I was just in a hurry and didn’t have the brake pedal down as far as normal or something stupid like that.
Happened once to us parked outside a pub in Nova Scotia. No codes, had a good look around, couldn’t diagnose a fault. It started as normal 2 hours later.
Chalked it up as a pause-for-beer-before-getting-anxious type win.
Not a joke...
That is common across some cars. Why (but that is just a guess for the Grenadier)?
Radio legislation offers frequencies which are free. That means the manufacturer has not to register and run tests for a certain range of frequencies. In Germany these are 433 Mhz and 868 MHz (some more) and these are mostly use for remote controls of any kind. The drawback is, that the manufacturer has to accept problems. That is the price to pay for being able to use this frequency with no further effort and cost.
We already saw Range Rovers and Defenders (like the 110 of my wife), which rejected to start or open. It happend with a Range in front of my house, where we could force the immobilizer with the garage opener of my neighbour. My wife parked at a fuel station next to another car. When she returned the car didn't open. She called me for help and I started driving to her. In the meantime the car next to her left and everything was working again.
So check your environment. has something changed between not-working and working?
433,92 Mhz is the standard for cars within the European Union. It could be 315 Mhz for the US for the door opener and the immobilizer.
You can check the number on your key. It might read something like FSK (Frequenz Shifting Key) and a number.
You can find that in the German "Frequenzverordnung FreqV" (Frequency Regulation).
The frequencies from 430 to 440 MHz are assigned to ham radio and non-navigational location finding use, code number D150.
Under D150 you find the following statement:
"Die Frequenzbereiche 9 – 10 kHz, 13 553 – 13 567 kHz, 26 957 – 27 283 kHz, 40,66 – 40,70 MHz, 433,05 – 434,79 MHz, 2 400 – 2 500 MHz, 5 725 – 5 875 MHz und 24 – 24,25 GHz sind für ISM-Anwendungen bestimmt. Funkdienste, die innerhalb dieser Frequenzbereiche wahrgenommen werden, müssen Störungen, die durch diese Anwendungen verursacht werden, hinnehmen."
Translation:
"The frequency ranges 9–10 kHz, 13,553–13,567 kHz, 26,957–27,283 kHz, 40.66–40.70 MHz, 433.05–434.79 MHz, 2,400–2,500 MHz, 5,725–5,875 MHz, and 24–24.25 GHz are designated for ISM applications. Radio services operating within these frequency ranges must accept any interference caused by these applications."
ISM stands for "Industrial, Scientific and Medical" applications.
The regulation on the European level are: 2019/1345 and 2014/53/EU
Not a joke...
We already saw Range Rovers or Defenders (like the 110 of my wife), which rejected to start or open. It happend with a Range in front of my house, where we could force the immobilizer with the garage opener of my neighbour. My wife parked at a fuel station next to another car. When she returned the car didn't open. She called me for help and I started driving to her, In the meantime the car next to her left and everything was working again.
I have also seen multiple cars with the frequency issue, hopefully that is the issue because that means they will never just stop and not start when in the middle of nowhere
Reactions: AWo
Just try it.
Drive here: S 54.423333°, E 3.361944
That is Bouvet Island, the most remote island on earth, as you were looking for the middle of nowhere. Try the remote control there. If it works every time, that is the proof.
No he's onto something. I reckon it's Automotive Havana syndrome. Check your environment 😉
No - I totally believe him. Frankly he could tell me that there were tiny Martians inside the engine and I would believe him. It’s just disturbing that one individual knows this much. I mean, he almost has the vast wisdom and insight of the Donald - bigly time.
In fact, there are tiny Martians inside the engine, but I still try to figure out, what they are doing (or not...).
Not a joke...
You can definitely block 433mhz by standing near a car being locked with a garage door opener with button pressed.
Once reason you should always watch the car when you lock it. A thief might jam your car from being locked then grab your full expensive shopping bags as soon as you walk around the corner.
I suspect that might not effect an immobiliser unless it had some kind of failsafe activated if it saw too much 433mhz interference.
Like I said, if you say it, in my book it’s Gospel truth. What should I be feeding them to keep the engine at peak performance? Is it like ET with the candy?
Happened to me too but it was the key fob battery, despite the car being nearly new. Changing it nd never had the issue since.
Perhaps looking for Elon to lead them into salvation?
