Ext 1 vs Ext 6
AZGrenadier
Global Grenadier #0031
3:11 AM
Hi all, I have done a search hear and remember seeing where the power lead us identified but can anyone definitely say which one is Ext1 vs Ext6 under the hood. I have found both as they are right next to each other, just wondering which is which. There is one flat along the fender line and another slightly inboard vertical. If I remember right the vertical one is the 25a but I can’t seem to find that verification.
Thanks
The 10 amp circuit uses the thinner wire gauge of the two. One is 10 amp, the other 25 amp. Ext1 is the 10amp circuit.
Is it Ext5 rather than 6?
full
Thanks
Where are the EXT 1 wires located? Do share a pic if you have one.
@Rok_Dr guide should be corrected: the EXT1 and EXT5 wiring preparation outlets are located at the other side of the bonnet for LHD (Left Hand Drive) vehicles.
My post here shows the location:
Or this image:
Or this image:
Thanks @Jean Mercier I’ll fix it in the next edition.
Cheers Steve
Or this image:
Thanks for the heads up. Now I know why I couldn't find any wires on the passenger side.
Just to confirm, there should be only 1 set of open wires on the Driver side, which is the EXT 1?
I only found 1 set of wires.
Yes, right, unless you have the extended electrical setup (double battery, etc.)
