Exhaust Systems
If I understand correctly, there is no welding required, even at the cut. Is that correct? I ordered mine a few days ago. I’m pumped! Especially after hearing how much you like yours.
The milltek variants I have seen are weld in, the Kooks clamps togerher and uses factory mounting points and is really well made.
The OEM exhaust is welded in and requires at lest one cut to remove, cutting once over the rear axle is the least invasive should you choose to retain or sell the old exhast.
