Dual Anderson mount
5teve
5:32 AM
Perth, Australia
HI all
Spent a couple of days (actually a couple of hours over a few days) refining the mount - mounts a 120a and 50a anderson into one of the rear bash plate slots - fits up ok - I havent wired it yet - and have a few concerns over the bend radius of the cable exiting the anderson plug as the heat shield is directly behind it. I'm not at the wiring point yet so hope there is room for a reasonably flexible cable.
Still on the fence for the rear clamps - ideally a stainless or painted steel plate with welded nuts but a decently strong 3d print I think will work well enough too (with enough walls and infill)
Happy to take on suggestions.. or if anyone wants to try it let me know
Neat. My Anderson plug is mounted in a similar position but is fitted in an off the shelf housing.
Steve
The NATO plug is within the wade height hence seal sealing cap. Is there a water sealing cap for the andersons?
