- Local time
- 4:44 PM
- Joined
- Jan 26, 2022
- Messages
- 2,010
- Reaction score
- 4,095
- Location
- Brisbane, Queensland Australia
Thanks for the update... which oil did you use?Third oil change is in the books , odo reads 8760 . from decision time to packing the tools away took approximately 45 minutes . (took longer to clean up than to do the oil change)
Once done and after adding my usual 7.1l of oil in the engine when checking the oil level electronically it came up with refill 1l for both on road and off road ( oil at temp ) . low oil light came on only after the measurement and not while the car was warming up .
I thought it was weird for me to make a mistake of that magnitude, 1 L seemed excessive . So i added an extra 500ml of oil just as a test . Re measured and came to ok for on road and refill 500ml for off road .
It seems the resolution of measurement is not the best . But anyway warning light goes off as soon as you start the measurement and never came back .
Anyway not sure what happened there , so will wait for next time to investigate further .
Next service will be the major at the dealer at 12000k .
Thank you guys
