Cruise control - am I going crazy? Gremlins?!?
parb
3:50 PM
Silicon Valley, CA, USA
I got a new software update about 2 months ago.
I went in a long road trip to LA. During this trip I noticed that cruise control deactivating itself when every 30-45 minutes. Can't think of anything it coincides with but suddenly the car isn't in cruise anymore.
No error messages.
You seen this? Any ideas on what is going on?
I've done many long trips prior to this trip and cruise control was flawless. What could have changed?
No error messages.
My cruise control can disengage when the road is turning left slightly (but not right) and there is a slight incline, this combination tightens the steering up slightly and disengages the cruise control. You cannot engage cruise control again until one or both of those things stop.
I have had the same problem many times and reported to the dealer. It will definately happen if ESC disengages and also if there is something amis with the steering. At one point the lock nuts on my steering stabilizer were tightened to the wrong side (by the dealer) and caused play in the steering which also caused the deactivation of the cruise control.
The failure of the so-called "gateway" module is a known issue by Ineos. Several forumites reported on this about a year ago.
Early stages of failure are indicated by intermittent faults including with the cruise control dropping out and and loss of power steering.
I had issues with the cruise control unexpectedly dropping out on a long trip... This appears to have been resolved with an upgrade to S/W 0000689002940 at the 12 m service. Power steering so far has been fault free🤞
I'm going to ask the dealer to look into this on my upcoming 12k service.
I'm also noticing android auto/bluetooth dropping every so often. it frequently reconnects by itself but not always.
They don't seem to correlate to each other but i frequently wonder if they are related.
I have experienced the same cruise control drop out, it only ever happens on left hand bends in the road, I’ve been told it’s probably a wheel alignment issue. I am having one done on Monday and will report back. (Oh it’s RHD vehicle too)
Mine drops out occasionaly when using spotify with Waze - looks like an Android bug rather than a Grenadier issue though.
Mine too. There is a particular road that I travel infrequently and the cruise control consistently bugs out on a left hand rising bend in a right hand drive Grenadier doing about 100km/hr. Suspect a bug in the software not an actual alignment issue.
Our iphone maps/nav system started to fail along with the cruise and yes they were both fixed by a software upgrade...does that make them related? Have not had an issue since 🤞
I'm aware of a RHD Australian vehicle that had this issue traced back to flexing of the steering box on the frame due to low torque of the mounting bolts. I wasn't given any further info but retorque of the steering box bolts resolved the issue in this specific case.
Cruise control dropout seems to be a safety response if a management system fault is detected.
Ok had my wheel alignment done today, it’s tracking better and feels a lot nicer, steering wheel is now at 12:00 when going straight. Did 20 minutes of highway speed (110kph) and the cruise control stayed on the whole time, no drop outs. Have a 4 hour trip coming up for Easter, so that will surely tell me if the problem is fixed. Will report back.
Ps the suspension place ( pedders ) said the factory alignment was terrible.
I have 4-5 bends that I often take between my [place and Brisbane that cancel the cruise control.
Left hand bends with bumps mid corner.
I was told it is sufficient for the speed sensors in the two front wheels to read enough difference to cancel the cruise control.
As I know they are coming up I have the thumb hovering over the resume button and hit it straight away.
Problem solved.
Problem solved.
Will let you know how the Easter trip goes, did it about a month ago( Newcastle to Emerald beach) and cruise cut out about 20 times, once or twice with the traction light flashing, Always on left bends. Hopefully this has been the solution.
Update,
Just did a 400 plus kilometre drive, Newcastle to Emerald Beach. Not one cruise control drop out after the alignment. I did the same trip a couple of months ago before alignment and it dropped out about 15 to 20 times.
Problem solved.
I drove back from Brisbane on Saturday and down from Coffs to Sydney today. I think my cruise is "up to mischief." I swear, I seem to be turning slightly left each time it drops off. It may have been dropping off a similar 15 or 20 times. I was consciously thinking about my actions for the full 1000 K. Even the co-driver noticed from the passenger seat...
My Grenadier has been out in the heat these last few months—19K, not a lot of cruise issues, maybe it might drop at a diabolical porthole or similar. Most roads we operate are graded, and we are not flogging the gear. I felt the cruise control drops seemed more prevalent today. It has been a few days of rain, and the Pacific Highway is rough after these weather events.
I have to drop the truck for some exploration on AdBlue issues, so the cruise control will get added to the list. Also, these few days of rain mean my door buttons are stuck after every use. The service agent's squirt failed within 24 hours; a locksmith's teflon dust might have been a better option as the interim fix, but what would I know? I drive my wonderful Grenadier and love its quirkiness. Eventually, I know these things will get fixed
I had the dealer look into it but they could not reproduce. I'll have to go on a long trip to see if the issue is resolved.
I somehow missed this thread a few months back when i did a search.
My cruise control has been cancelling on left hand bends only - but very intermittently, like once a week, 10 times a day, not for a fortnight etc.
I reported it to the dealer from about day 2 ownership and the dealer has "investigated" it at all of my first 3 services - but tonight they tried to charge me $180 because they couldn't find a problem...WTF (They had forgotten to charge me the $180 at the last service 8 weeks earlier!!).
Maybe Im unreasonable but i refused to pay and went through 2 staff before i got to the manager. He relented but what?
I will send a screen shot of DennisM's thread reply above to the manager and see what he has to say.
To top this off, the car wasn't even in for a service, they had had it for the last 2 days to replace all the door lock mechanisms (which were basically permanently jammed) and fix the lack of a heater which last week was causing the windscreen to freeze (it was cold here in Tassie last week). Did they replace the lock mechanisms...I think so. Did they fix the heater...NO...Needs a new thermostat apparently, that will be another 2 weeks wait for one to turn up.
Does anyone in Australia get good service from their dealer? We only have one option here in Tas as the three locations are all part of the same motor group, as i understand it. Their customer service is lacking to say the least. Im now onto the 4th person who is the Ineos contact (thats in 8 months) and i dont see any of the previous people there. Despite its quirks and problems, I love the car, but the servicing and warranty experience here in Launceston is so bad (imo) that i wouldn't buy another.
My rant over, now its beer O clock
