Connecting a USB-A stick or drive to the infotainment screen
The fatsort tool that lewma pointed me towards above does work, but it’s not for the tech faint of heart. It’s a command line tool that taxed a decade+ unused part of my brain that actually once knew how to use UNIX.
For now, I was able to get the USB to show up in the grenadier and browse folders and all the files were in the order of their file names. Fat32 256gb thumb drive with .WAV files in separate folders for each album. All files included the track number and should be alphabetically sortable as such. It did not, as far as I can tell, read any metadata in the files and as you and others have said it simply reads the files in the order they were written into the directories. If I understand it correctly, the fatsort tool simply rewrites the order of the files in the fat32 directory system. Voila bobs your uncle you now have a grenadier reading the files in the intended alphabetical order.
Until there is a software update that can address the way the filesystem is read, or even can scan metadata (such as ID3 tags) within the files themselves, I see no other solution.
There was an app version of fatsort but I felt like a challenge. No surprise since I’m the kind of guy who buys a grenadier fully aware of it’s idiosyncrasies :)
I have taken the USB stick from my last car, but yet to pop it into the Grenadier.
Once I have, the next challenge will be trying to stop the Mrs putting every bloody song taylor swift has even recorded and ruining my playlists with taylor bloody swift :)
I use SDSorter for my digital audio player running Rockbox (https://www.trustfm.net/software/utilities/SDSorter.php) with my truck. It supposedly works with any removable USB drive, but I use it primarily for the SD card in the DAP. Pretty straightforward to use, so might work better for those with USB sticks ? It runs a bit slow, so if it looks like it hangs up on a file - be patient.
has anyone tried a new stick, then copy the files/folders to that stick in the order that you want them displayed ? I think FAT32's default sort order is the file/folder creation date
I wanted to follow up… after using fatsort last week to clean up the sort order on my usb thumb drive my head unit has continuously recognized the files in the folders as I sorted them using fatsort (alphabetically). So, this tool seems to be one trick if you’re hellbent on using a thumb drive. It’s not for me. Too much work and even after using a highly technical workaround to get the head unit to behave with reading the files the interface is just clunky.
My main intention with using a thumb drive was being able to play cd quality WAV files and I liked the idea of being able to just leave what was essentially a giant CD carousel in the car.
Going forward I’ll probably mainly plug in my iphone for listening to hi-res audio. The Files app iOS 26 has made accessing the file system easier than ever so I can copy the files into the directory for another app. I like VLC, it’s recognized in CarPlay and does the same thing I’d want from the thumb drive minus just being able to leave it in the car and have it pick up where I left off every time I turn on the car.
Thanks for all the input I’m glad I have a solid understanding of how the current state of the firmware in the factory head unit works and can stop laboring over it now.
I use the youtube music app and download tracks to my phone so I can access them offline. Seems to work fine.
