Coil Springs (specs v build)
I've been following this thread because of planned mods. Despite the talk of NAS models having different springs I have the double green circle 19546's up front on my 8/23 build. I figure if these can handle what @Logsplitter is doing I'll be fine. Do any NAS owners have the reds? Build specs are in my signature.
I do have the red 21751 in the back.
I have the same spring up front, and the red triangles in back.
Nice. Looks like you have the roof rack, but no steps or winch? Are you planning on adding either of those at some point and do you anticipate needing a spring change up front?
Buzz sliders will be installed in about a month. I’ll take measurements from the bottom of each wheel rim to the top of the fender opening. Then see if they settle, and if any change with the sliders.
Just checked. I have a stock TM with tow package - no other options that would impact the weight.
Green dots up front and red triangles in the rear.
Weirdly I have a stock FM with tow package. Again, nothing to impact weight but I have Green dots and Green triangle.
You have K02s and I had Bridgestones - I wonder if that may be the reason for heavier springs?
Adding an unusual combo - Sept 2023 build TM with steps, bull bar, brush bars, winch, rough pack. Front springs have no colour dots but part number 19548. Rears are blue triangle 21752.
Actually, what surprised me most was the overall diameter of the rears and the diameter of the wire used - they look like they would belong on a Unimog and are certainly far larger than the ones on my old Defender.
Thicker wire makes spring harder but larger diameter softer as length of wire increases. So spring rate may not be that much greater.
My experience on standard diesel (no winch) springs is very positive, they work fine on and off road. Sorry, no codes.
Not sure if this thread is still alive but I found it after searching for info about the clearance under the front bump stops, which a wheel aligner who had never worked on a Grenadier thought was insufficient at about 15mm.
Also, my rear springs have the right number for green triangles but have green circles instead.
Details:
Front - Green circles
Rear - Green circles
Market - Australia
Type - Grenadier five seat wagon
Edition - Base but with diff locks
Seats - Five, heated leather fronts
Engine - Petrol
Winch - No
Roobar - Yes, with side bars and sliders all added by dealer
Aux Batt - No
Wheels - 17" with BFG
Towbar - No
Details:
Market - Australia
Engine - Petrol
Winch - No
Aux Batt - No
Towbar - No
Hi @Ron50
My build is different so I cannot compare spring fitment. Diesel, tow pack and aux battery.
My front bump stops are similar, maybe only 10mm between the stop and the seat at ride height. Clearly we have more than 10-15mm of suspension travel so I'll presume a fair portion of the stop compresses with travel to provide cushioning.
Thank you to all those that provided the data requested - all now added to table:
And for those new to the thread and want to understand what the colours mean:
DCPI
Do you have any further updates on the table you created. Also want to contribute mine
Front - Two green circles
Rear - Two Blue Triangles
Market - Australia
Type - M1
Edition - Trial
Seats - 5
Engine - Diesel
Winch - No
Roobar - No
Cill - No
Aux Batt - Yes
Wheels - Alloy 17" - Dueler
Towbar - Yes
Looks like I'm on the softer front springs as I didn't option the winch and the harder blue on the rear to match the tow package
Just to add to this, as I currently have a broken spring and I want to replace it with the +30mm versions ideally as part of the warranty repair. I have written to my dealer but have no reply as yet.
One thought I had is that I remember reading somewhere that the African spec versions were fitted with the taller spring from factory? Can anyone confirm this? They’ll presumably have a different part no. Can I ask African owners take a peek at their springs and check? That would be much appreciated.
It would be helpful if more recent owners helped to update the table in this thread, its a useful resource..
Cheers!
This is very interesting as I am installing a winch tomorrow and I will look at my springs to see what I have. What are people doing to change the springs? Would the Eibach lifts help? They are not really listing spring stats just that they are taller.
So If you have soft springs and are adding a winch and a roo bar what would you do? Go to Ineos and get higher rated springs or after market?
Eibach makes standard size heavy duty springs. @anand add some to the rear of his truck.
Latest posts
