Centered steering wheel when going straight?
parb
4:05 PM
Silicon Valley, CA, USA
My steering wheel is off center when driving in a straight line. Is this an easy fix? I took these twp picture of it, it's about where these pics show the wheel to be when going straight.
It's not super awful but I find it annoying.
Get your dealer to fix it under warranty, they will do a wheel alignment to fix. I had the same issue but other side of the vehicle and 10 degrees permanently to the right, had it done at the same time as getting all remaining service campaigns done.
Like Shopkeep said - go to the dealer for alignment. Had a similar issue and wouldn’t take the car until it was addressed. They had to get Ineos involved to try to address it. It’s better now but not perfect.
Yep that is where mine is at. Having it addressed at the dealer in a couple of weeks.
Cool, I have an appointment in early October. I can wait until then. Closest dealer is still 5 hours away from San Francisco.
Hi Parb, Here's the fix for an off centered steering wheel. DaBull
I decided to tackle the 2-degree steering wheel offset from top dead center that my Grenadier had. I hate to admit it that is was driving me a bit batty. Although I knew having the steering wheel moved to top dead center would not change anything except my perception, I am loving the new perception.
These instructions are for the US Left Hand Drive Vehicles. Not sure if they would be exactly the same for Right Hand Drive Vehicles.
TOOLS
WD-40 to first spray on the captive nuts and threads to make it easier to release the captive nuts.
2 large adjustable wrenches. I purchased mine from Harbor Freight.
3M blue tape and permanent marker to set up a reference scale, see photo.
Something to lie on while wrenching away.
Tef Gel or anti-seize to put on threads to make it easier to undo the captive nuts the next time.
Some Red Paint to mark the final adjustment.
A bit of strength to wrench loose the captive nuts, it helps if you know which way to turn them first, which I did not.
Here’s a couple photos on how to go about adjusting the steering wheel to be top dead center. Note: This does not change the alignment of the suspension.
One photo has instructions and the other shows a strip of blue 3M tape I marked up and wrapped around the large wide center nut so I could visually see and make note of what adjustments I was making. The numbers are just for reference and could have easily been A,B,C instead.
Once you have the 2 captive nuts loose, you can then turn the large wide center nut. Simply make 1/6th turn adjustments at first and then take it for a short drive, (Yes, I know you should tighten up the 2 captive nuts first, however I choose not too during the test drive). Keep in mind when taking a test-drive that most roads have a slope/slant that falls off to the side to facilitate drainage during rains. As such, you will find the steering wheel will be 1-2 degrees off for the vehicle to compensate for the sloped road. The trick is to find a level road and then drive it in both directions to judge how well your adjustment is working on level roads and then make further fine adjustments from there. I took my wrenches along for the test-drives and pulled over and made adjustments as needed until I was happy. Once back home, I spread some anti-seize, (I used Tef-Gel), on the threads to make it easier to wrench them loose in the future and then tightened up the captive nuts as hard as I could. I also purchased a small paintbrush and some red paint to make a straight line across the all the nuts so that I could easily peak underneath from time to time to make sure nothing was coming loose. It’s very important to tighten those captive nuts and keep an eye on them to make sure they are not coming loose!
Now that I have finished this project, Everything In The Universe is Now Perfectly Aligned. DaBull
My
Woah! You took my method to the Nth degree! Nicely done! 💪
A LARGE SHOUT OUT TO @LeftCoastOverland, as he was the inspiration for me tackling the steering wheel correction. His detailed information and photos on his original post gave me the confidence to tackle this head on.
Thanks @LeftCoastOverland
Much Appreciated! DaBull
Here's LeftCoastOverland's original post:
No credit to me required, Amigo!
steering centered.
All it took was a very expensive 46 key and two 36 keys :censored:
Is that the wrenches you needed to loosen the nuts? I'm debating buying fixed size wrenches or two large adjustable ones.
exactly, they are the necessary wrenches. I prefer them fixed
Let me start off with, we get our Grenadier tomorrow. Does anyone have access to the wiring for the power steering pump motor, back to the ECU? Some of the pumps I used in the past (old hotrods) will whine at different speeds. I am thinking that the pump motor may be a variable speed and controlled by the ecu; or just have a simple relay to turn it on and off. Either case, I would think that it would be easy to disable for the times you idling whilst pulling up to order fast food. I would always have to turn my diesel engines off so they could hear me.
TOOLS
View attachment 7865432View attachment 7865433View attachment 7865434View attachment 7865435View attachment 7865436
My
Really appreciate this info so I can fine tune my top dead center to my exacting specs. Thank you, sir.
Anyone have both nut specs handy? Need to buy some wrenches. Gracias.
I did mine in a much less scientific way, took me five minutes. I set the steering wheel to its offset straight ahead position. I loosened the lock nuts, rotated the drag link by hand and would simply look through the windshield to see when I was centered. When it looked correct, I got in the drivers seat to confirm and made one tiny additional adjustment. Locked it back down. It was around 2-3 degrees off to start with. It was enough to start a series of warning lights and to prevent cruise control from functioning.
A second person sitting in the driver’s seat would have made this a 3 minute job. Its not a. Alignment per se, just a drag link adjustment.
Hello together,
I tried to do the job yesterday too. Wanted to do it the less scientific way!
I'm sorry I'm to weak to get the nut loose. Will have to go to the gym or to find a longer pipe to get more power on the wrench! :unsure:
Regards Sauerländer
Hello together,
Regards Sauerländer
Mine wasn’t tight from the factory which is likely why it was off a bit. Leverage is your friend, they’re supposed to be torqued down tight. A very big adjustable wrench works, a pipe added to it will make it a super sized adjustable.
