Australasia Caravan towing (OZ)
4:41 AM
Melbourne
I am very seriously looking at the grenadier to replace my BT50.
Just want to ask a few questions to help me with the decision:
1) Is there an adapter available from the round NATO plug to the standard 12 pin flat (caravan) plug. And ditto for the round 12 V NATO to an Anderson plug
2) if I need to use a drop hitch for the caravan (off road Atlantic) to get my caravan level what is available for the ineos.
3) can I replace the in-built driving lights with strong LEDs
4) can I rejig the wiring for these to be triggered thru the high-beam circuit
5) towing mirrors????
6) where are people mounting the UHF radio, hand piece and aerial
7) I use a TPMS for the bt50 and the 4 caravan tyres, will this cause problems with the standard grenadier TPMS
8) where have people mounted their caravan sway control (eg Elite pro) control switch
Cheers Brian
For a start, you have to bypass the NATO activation solenoid to get power when driving.
Some of us have built their own NATO to Anderson adapters.
My UHF is mounted beneath the glovebox and a magnetic handpiece mount is placed just tothe right of the console.
Oh and I use bluetooth Elecbrakes, avoiding a hard wired Towpro unit.
The NATO plug is not really suitable for supplying a caravan. It is designed to service a winch and therefor supplies high amps. There are also conditions for it to function, I think it cuts out when the vehicle speed exceeds 80kmh.
For towing electrics to the caravan I kept the factory European style 13 pin round plug and use an adaptor to take it down to a flat 7 pin, available from Autobarn. The European style plug is well wired in and looks pretty water proof.
I fitted a Redarc Towpro Elite brake controller and put the switch in the centre console near the handbrake. It can be easily reached by driver and passenger if you need to tap it to activate the brakes for sway control. I see that Redarc have just released a Bluetooth controller and I would have installed that if it were available at the time. Running the cables for the Towpro Elite was a bit of a pain and I would not have had to drill holes in the centre console. Here is the link to the new Redarc Wireless
I fitted my UHF behind the glovebox, use the John Canny YouTube video as a guide for running the aerial cable through the firewall and positioning the antenna on the bullbar. Pick up the power supply from the INT 1 wire in the footwell. For mounting the handset I 3d printed a bracket that sits on the centre console. I put the magnet from a GME Magnetic Mount into the homemade mount.
Mirrors, I just used the old clip-ons that I had from previous vehicles, nothing special, they do the job.
1) there is but I just had Expedition HQ wire in a 7/12 pin kit.
2) Item 40 under first heading: TOWING HITCH (AU): look under the heading TOWING GEAR in this thread here (AU focus);
3) Yes, it is also fairly easy to fit a 20 inch Lightforce Viper to the roo bar (if you get a roo bar). Items 20 to 22 under second heading on supplied link above.
4) Yes, using a relay to the high beam circuit. The spot lights need to be turned on from the overhead console, so they are not accidentally triggered on the steering wheel stalk.
5) None from Clearview or other suppliers yet. Need to look at a Universal fit. I do not need them as my van is smaller.
6) Item 40 under second heading: UHF (CB) RADIO: How to install a UHF (CB) Radio in an INEOS Grenadier without drilling any holes here (RHD cars only) and fitout here. LHD drive cars look here and here and detailed video here. Aerials can be mounted on roo bar, roof rails, passenger side mirror (you need the KAON bracket), roofrack or at various places at the back, including the L Track.
7) No reported cases I have seen.
8) No idea.
Here's some thoughts and ideas after towing heaps. 3100kg van 280 on the ball thereabouts.
Nato socket is fine for powering van - it is 'capable' of 350amps but will only supply whatever your dcdc requires and this should have it's own fuse from supply. As said by others, it does need a new 12v feed to the Albright solenoid otherwise will not really work. Some as I have used one of the overhead switches to power the Nato socket..
The 13pin Euro plug is far superior IMHO to any other flat or round available here. No bad earths, nor does it fall out - it has a cam lock. Perhaps consider changing your van and carry an adaptor. There are spare pin positions in the 13 Euro that can be used for your van rear camera. (the pins need to be sourced but easy enough)
Perhaps consider driving the vehicle at night before modifying lights - they are very good.
A wolfbox powered rear view mirror with replacement mirror brackets is a good investment.
Consider moving the rear camera of the car to centre.
Plenty of places for the UHF and tow module with easy access for cables/power. I have my redarc module attached to a bracket near the spare battery compartment and UHF on a bracket behind a panel under the steering wheel.
If you like to work on your own vehicles and do installations then you will be very happy with this vehicle as it's well set up for this purpose. Also tows extremely well. I did have to get a 3800gvm upgrade with HD (Black Eibach) rear springs from Expedition HQ. Here's some pics and there is plenty of info on the forum.
Redarc controller and radio mic mount.
Phone on powered quadlock mount.
Redarc near Aux Battery location
Antenna cable runs up B pillar and out of power gromet.
New power feed to operate Nato solenoid.
Moving rear camera to centre - makes hitching up much easier...
Towing indicator light
I have the XHQ REDARC tow pro kit installed on my Grenadier using a 7/12 pin trailer plug. It uses XHQ's own wiring loom. It replaces the 13 pin Euro plug.
When towing the new caravan I noticed a new light illuminating on the dash. When the left or right indicator is on and you are towing it shows the indicator signal is also going to the caravan/trailer.
Two lights blink, the indicator light plus the indicator signal to the caravan/trailer. The new light was located towards the bottom right corner of the dash. Both lights were flashing green. From memory, the new light is a combination of the blinker light icon over a "box cart".
I swapped a couple of emails with Clearview over the past week (Dec 2025) about towing mirrors for Grenadier and QM. This was after I had registered interest via their new vehicle request form. This was sent back today via Customer Service:
Bold added for emphasis
Question: Do you have an idea of the minimum interest numbers that Clearview needs to proceed with development, and would that include international sales? This vehicle is quite popular in the USA and to the best of my knowledge no one is doing extended mirrors there either.
Clearview Response: I have spoken with the team in regards to your email. From what we can see, 8000 units were sold in 2024 out of the USA and dropped 14% in 2025. Due to this, it is highly unlikely that we will ever go into development for these mirrors."
Presumably '8000 units' is new vehicle sales.
So if you're waiting for an integrated extended mirror solution hit up MSA and let them know the market is wide open.
Plus these if that suits your needs https://www.alu-cab.com/products/ineos-grenadier-mirror-extensions/
The product photos from that link appear to contradict this…
What's the go with the "not compatible with electric mirrors" statement?
Yeah I'm not quite following that either. It's just a fabbed spacer that pushes the mirror and mount outwards so why doesn't it take the mirror functions with it? Unless it's a harness length issue and they don't want to sell an extended harness 🤷‍♂️
This setup would suit my narrow track camper. I haven't followed up to see if an Australian Alu-Cab dealer can get them in as an alternative to paying freight from SA.
For my money I'd like to see a spacer block like this that sets the RHD driver's mirror slightly more outwards, and sell them in a couple of widths. Or, make a single width and sell a 2nd add-on spacer and a longer bolt set so you can pick the width you need, i.e. wider or widerer. But, please enclose the block and lose the light mount. That Alu-Cab bracket is a bucket of smashed crabs ugly. My opinion only 😁
When I contacted them in 2023, they were not interested.
Sounds like not much has changed. Lucky for me, my van works fine with the OEM mirrors. I have full vision down the van, but it is a smaller van.
Way bigger numbers with the Prado 250.
Clearview? Yes it seems they need a larger market to play in.
My hybrid camper is 1950mm wide so just like you I can see down the sides to the back corners. That puts me in the 'not required by law' category because my camper is narrower than the width of the vehicle (mirror tip to mirror tip). At a recent VanSafe weighing event one of the scrutineers softly argued the factory mirrors on the Grenadier were not enough because I could not see a vehicle close behind me. We debated the minimum trail distance (there are a few figures and diagrams published, he says they're all made up by third parties) but it was an educational event not a compliance event so he was offering suggestions not making an argument.
On my next towing adventure, a 1300km round trip, I did half the trip with the factory mirrors then fitted some strap-on extended mirrors for the return trip. He was right. My situational awareness of what traffic was behind me and the travelling gap was vastly improved. He was telling me you're definitely not illegal but you could be doing it much better. I now completely agree. I don't want the bulky extendable mirror heads that Clearview and MSA produce (though they're good for reversing) but something like that 82mm extra width on each side from the Alu-Cab brackets would be the sweet spot for me.
I have also contacted KSource in Australia to see if they might be doing snap and zap clip on mirrors for Grenadier. Also, if their JT Gladiator or JL Wrangler mirrors might fit (the mirrors look similar and I have sent them the dimensions). I don't know because I cannot get the distributor to respond to an email.
Example
My van is 2290mm so reasonably wide; I've used a cheap clip on mirror from Supacheap which after strengthening.modifying the mounting has survived.
But we don't have Gibb River rd like corrugations here.
I'm not sure anyone will have the motivation to create a Clearview type solution unless a lot more Grenadiers hit the market. Of those sold , what percentage actually tow anything wide? Let alone tow rough offroad?
Towing performance is a common question from interested punters on the Aus FB groups. But as to how many are out there doing it and how wide, 42?
A full size van with an island bed is out there in width and that's a popular configuration.
I'm probably using the same SCA mirrors as you. OKish but not robust. More Rocky Burnette than Rocky Road. I'll improve them a bit before the next trip. I have no confidence in the elasticised dental floss they provide as a safety retention cord. All that is going to do is guarantee a dinged door.
Cheers Brian
1. It costs around $400 for an autoelectrian to do the proper fix and provide a permananent power source to a new Anderson external plug with new 7 pin trailer plug above it replacing the 12 pin Euro round plug.
2. Hayman Reece supply a suitable drop/rise tongue for less than $200.
3. Yes, as I have alreay done. Around 49 screws and 2 hours work. You will need to use a solenoind with power feed from the Ineos supplied external power tucked under wheel arch at left of air box as the standard driving lights power feed is too small. I wired mine such that they only come on when the overhead switches for spotlight and highbeam are on.
4. See response to 3.
5. Yes a pain - still looking at options.
6. No - unlikely as the sensors are paired to the wheels and then to the control/display unit but will not be displayed within the TPMS of the Grenadier as it is a different system.
7. Mine is mounted under the glovebox at passenger footwell. Be careful not to obstruct the cabin filter. Handset is mounted on magnetic mount under central air vents, no drilling of holes required. Cable sneeks out between joins in trim to left of steering wheel.
8. I have mounted by additional controls such as throttle controller and brake controller to the right of the steering column under the tell tale cluster.
I get my Conquereor UEV 570 in Feb but have done all of the mods as above.
