Brake pads
Can’t remember exactly but 18-20k miles
Were yours catching, or are you hard on the brakes? Mine's on approx 22k and no warning yet. Due in for service mid September, should be on 24k plus by then.
I think you have to take into account the amount of heavy towing you do. My Discos all went through rear pads quicker than normal with towing. I'll be interested to see how the rears go in the Gren
Reactions: CRH
I was trying to remember a post, which i thought was yours, about the pads wearing and speculation as to why.
Is rear brake pad wear normal when towing? I haven't towed for a long time now.
I didn’t get any wear indication. I left my vehicle in South Africa for servicing before shipping back to U.K. The garage contacted me to say brake pads need replacing. Hopefully they weren’t hoodwinking me
Reactions: CRH
Normally it is the front that wear the most, since the weight is there and the weight is transferred forward when braking. When towing in the UK we are " blessed" with overrun brakes. There is a slight delay when the car brakes and the overrun brakes activate. That pushes on the back end of the car, which must take the initial braking. Secondly overrun brakes are drum brakes whilst usually the vehicle brakes are more efficient discs and can/ do take some of the braking force of the trailer dead weight.
Thanks Mate. I got the brake wear alarm and waiting for the brake pads to arrive. Will post the result in either case.
I went to a reputed local workshop yesterday and got the pads replaced. I can confirm that they fit as a glove and the brake wear alarm has automatically disappeared. these are the ones I used. Thanks @Greasemonkey.
I am watching this space as I had my brake pads replaced and the OEM brake pads are ridiculously expensive.
Yes that's why I went the other way after the dealer quoted me USD 800/= to replace the front pads only. They think because we own a Grenadier we must also own a bank!
I replaced the front and rear pads yesterday including disk skimming for USD 220 labour + USD 73 parts. If I had my own A/C workshop at home I would have saved the labour cost but I couldn't do it myself in 45 degrees Celsius.
I’ve found in the U.K. that garages wouldn’t fit brake pads that I supplied. But I’m confident a small independent might and it certainly wouldn’t be a problem whilst on travels through less developing countries.
Cruise/speed control can kill brakes.
At this point, I'd also like to thank @landmannnn for discovering that EBC had listed brake pads for the Ineos on their website. Using the EBC number as a comparison number, I found the Brembo brake pads. The most important insight for me during this search, however, was that you can identify brake pads based on their dimensions using the so-called WVA number (Ineos WVA 25112 and WVA 25147). By searching using the WVA number, you can now find numerous manufacturers that offer identical brake pads. I didn't know the purpose of this WVA number until now.
Fortunately, @yedaiwi also volunteered to be our "guinea pig," so we all now know that these brake pads fit and that you can buy pads for the Ineos for just under €60 in the future.
Perfect I’ve added that to my Grenadier photo album.
"Ineos WVA 25112 and WVA 25147"
Well if it's good enough for a Renault van it's good enough for our French built Grenadiers!
