Brake pads
ScottishGrenadier
12:01 PM
Scottish Borders, UK
Wondered if anyone had found any non genuine Grenadier brake pads for the front and rear calipers? I have tried tracking some down but have consistently drawn a blank so I'm curious to know if anyone else has tried?
I thought they were Brembo pads, can't you get them direct from them.
EBC do them. About £90 front and £60 rear.
Thanks for this I will have a look.😁
The fact that these pads also fit another vehicle shouldn't be a problem, as Ineos certainly hasn't reinvented the wheel and uses parts that are already available on the market. I know the picture of the EBC pad is just an example. However, if the EBC pads have a retaining spring at the rear, they might not fit. Especially if there's only one spring at the rear, as the Ineos' front brakes have a dual-piston caliper. Someone should order some and compare them.
I ordered some last night so will keep you posted. A friend of mine had his Grenadier serviced and the pads fitted at the Ineos service centre were a hefty price.
Brake pads arrived yesterday no clips on the back of them so look correct. Service tomorrow so will see if the Service Center is happy to fit them.
What milage are you on to need new brake pads?
My brake pads also arrived today. If they do not fit, I calculate the costs under experience.
Thanks Mate. I got the brake wear alarm and waiting for the brake pads to arrive. Will post the result in either case.
I am watching this space as I had my brake pads replaced and the OEM brake pads are ridiculously expensive.
Is that from the dealer fitting genuine IA pads (Brembo), or the Brembo pads direct themselves??
I had the Ineos dealer in Cape Town replace the pads as they were apparently very worn.
