Bigger tyres > 255/85r17
K1LL3M
1:32 PM
AUSTRALIA
I've just done a test fit with Mickey Thompson (MT) Baja Boss AT tyres in 255/85r17
The MT website states the tyre diameter is 879mm (34.606 inches). MT tyres run big with the calculated size of a 255/85r17 being 865.3mm
Of interest MT quotes a true 35x12.5 at 876mm (34.488 inches) so these 255/85s are just 3mm bigger than a true 35 (basically would be a 35x10.5)
The tyres sit inside the guards and do not scrub anything lock to lock. Not sure how it would work flexed up though. Fitters opinion is it will hit bumb stops before guards, but I'm not sure, I'd like to test that one.
Opening the rear door misses by millimetres. Probably 3-5mm. It is so close on the back door, I am wondering if there is any play in the bracket to pick up a few mm and save $800 ish incl postage on the black sheep wheel mount.
A true to size tyre like this would be perfect I imagine, but it does appear only MT are doing these.
This tyre and size appears to be popular in US FJ market and maybe some jeep, but there must be some demand in Aus for them to be available here. Hopefully will stay that way
I am still waiting on the Eibach lifted springs and new rims to turn up, which I think should all work nicely together, if I can just get the spare to work.
Yeah I mentioned a while ago I’d be happy to run 255/80/17’s in lieu of 285/70/17’s as both are 33”.
The problem in Australia is it isn’t a popular size with very limited options, particularly in AT’s. As such trying to get one if you need it out west would be a tough ask, and you’d potentially have to get one shipped in, whereas 285/70/17’s would be everywhere.
What are the key benefits you see of changing to the 35" tryres?
Note that these are 255/85
What are the 255/80s that tou mention?
I know it is an issue with uncommon sizes, but I also think its a rare one. I feel the reward outways the risk
Feel like this is a loaded question, but I will answered it honestly. 35's arent the benefit persay, they are an arbitrary tyre size that we can get away with.
The benefits come in the taller tyres used with an increased ground clearance and greater side wall. Taller tyres when aired down allow a greater contact patch, they allow more tread to wrap over rocks and float on sand. They provide greater "cushioning" on rough roads and corrugations.
many thanks - I appreciate that (nothing loaded!) and will do further research.
at this stage my inclination is to stick with what the car came with and see if that meets my requirements over the coming 12-18 months and if not, then change up.
cheers
In the US we refer to the 255/80s (and their 255/85/16 counterparts) as the pizza cutters. Very common among 3rd/4th/5th gen 4Runners and their Tacoma counterparts. I've run them for years and plan to on the Grenadier as well. They are just a hair taller than the traditional 285/70/17s, but, as I'm sure is true with the 255/85/17(in comparison with a 285/75/17 or 305/70/17), they will fit with much less work due to their narrower tread width. They are also available in ATs (Falken Wildpeak A/T3W's are my go-to)
Yeah 35’s in your case not 33’s I get that. I was looking at 255-80-17’s in lieu of 285-70-17’s for the same reasons you probably were.
My point was that they are as rare as rockinghorse shyte in Australia, so you leave yourself open to not being able to get them in need. A quick search of a few dealers would suggest the Micky T’s are the only ones available here.
But if you love em, hook in.
@grenadierboy 100% no need to change until you know you need more. Or you just want to. Your car, your money, your passion. We dont always need a reason.
@anand i just checked, we dont get the wildpeaks in that size here. 255/80s are basically a 33. Will be no problem fitting them like the 285/70s that I have seen others run, as for the 285/75 has also been used
I have tried a 295/70 (trying to get at least 34" tall) and it works with out a problem. Even on the back door. But Ibwould prefer to not be so wide. The 255/85 is just that bit taller and just fowls the rear door. But they do fit the on the car with out any other modification need
👏 👏 👏 Well done on trying the different sizes!
Thanks for the info, I’ve been considering the same size tyres. Kenda also do a tyre in 35x10.5”
You also mention you’re waiting on springs and rims ? Keen to know what rims you’ve chosen, and are the Eibach springs already available for purchase ?
Thanks
Ben
Thanks
Ben
Thanks for heads up on the Kenda. I was just about to commit to the Mickeys but will check them out first now
Rims coming are Evo Corse DakarZero 17x8 p45
The Eiback springs are on pre order, expected early December
If you're interested in getting your name on a set contact
John Kayik | Sales Manager
Eibach Suspension Technology Pty Ltd | 3/4 Prosperity Parade | Warriewood NSW 2102 | Australia
T + 61 2 9999 3655
john@eibach.com.au
www.eibach.com.au
T + 61 2 9999 3655
john@eibach.com.au
www.eibach.com.au
Thanks for the info I’ll get in contact with him.
Let me know what you think about the Kenda’s. Did you happen to get a price on the Mickey T’s ?
Somewhere between $585 and $610 each. Look to be a bit more expensive than the Kenda, but I think I prefer them
hello, did you tested the 34 inch offroad now? i have the same idea with 255/85/17 . but i am absolutly not sure about the eibach springs. there are only springs no new shocks. can this be good?
After investigating the 255/85s (these are 35x10s) there is legality issues in Australia.
The actual measurements of 255/85r17s is 879mm which is greater than 7% in diameter over the largest 255/17r18 wheel (814mm) fit to the vehicle.
This means engineering certification is required, and because the vehicle has esc, the cost is north of 25k to get this. Not worth it.
So 285/75r17s it is (34s) which fit the the car, and fit the door. Only problem is not a lot of choice in this size.
Yep -apparently no one likes skinny in Oz.
