Bicycle Carrier on spare wheel
Yesterday I bought this rack and it's not compatible with the Grenadier 😞
Fabbri, in Italy, makes one called the Gringo Bicci. You can get conversion kits so it can carry 4 pairs of skis, 2 snowboards (or 1 snowboard and 2 pairs of skis), or 2 bikes. For the stock Grenadier wheels, you will need the 300mm extension cables, as well. It’s quite light and mounts in about 1 minute, once you do the initial setup, which is very easy. I don’t use it for my mountain bike (I use a Thule hitch mounted rack with an extender bar) - just skis, but looks like an interesting option. One thing to note - I believe the Fabbri touches the frame - my bikes are carbon frame, so I prefer no-touch options. The site says it’s carbon frame compatible, so I think the part that touches has protection for the frame. If you want a spare-mounted rack, however, this might be your best bet.
I’ve also attached a picture of mine, which is just configured for skis.
I also tried to install the Yakima and did not manage to do so. Yesterday I installed a French model, which seems to work fine: https://www.mottez.com/de/produits/porte-velo-4x4-sur-roue-de-secours/
Can upload pictures later.
Things to consider:
- not as lean as the Yakima (no folding of the upper part)
- assembly takes a while
- creates issues with the parking sensor (there might be a fix for that)
I use a yakima, like above, but I have a model where I can offset the upper part to compensate for an offset tire. I also replace the mount extension with one fabbed from stainless, otherwise it can rust together if left on.
Is it the Yakima spare tire bike rack? Do you have a picture, by any chance?
Ah, on mine I can move the spacing of the wheel holder and upright. I needed to after coming from the Discovery. So no spacer needed. But yes I can only open the small door with it in place.
Do you have some photos of the set up. I use the Thule rack for two Bikes, but it is a pain in the arse fit. Anything that would drop the height and push it back a few inches would save a load of stress
Installed an Allen bike rack today! I wish I could’ve installed a Thule it looked much better but this one does the job.
Just stumbled onto this thread. I needed one too and just like @terdrocket I went the lolo rack route. I have their 4 bike shuttle rack and love it. So I fabbed a removable rack that mounts to the ladder. it works great so far. Its not as robust as a hitch mount rack such as a Rig'd or lolo, but that is mostly because I do not know the ladder load capacity(other than stated static load). But for me to rip down the highway and forest service/dirt road this setup is great. I have a few more tweaks that I want to make then I will post some pics. It holds two mountain bikes by the handlebars, is removable, and it is adjustable.
Glad I finally bit the bullet. 1Up offers a version of this (the RakAttach), but it is quite a bit more $$. Plus I think this one from Kuat is at least as good, if not better quality based on research (not personal 1st hand experience). And I bought the Kuat on Amazon, so free shipping, vs $69 for the RakAttach factory direct.
I don't know anything about motorcycles.
Apologies, the bar clamps look like motorcycle risers so presumed thats what they were. Im Just struggling to find some that match the dimensions i measured the ladder at, so thought you might remember what the inside diameter was of the ones that worked for you.
This is what I used.
