Bed Step solution for Quartermaster?
HarrisonUtahOffRoad
Quartermaster Owner
Forum Supporter
6:20 PM
Utah USA
Has anyone found a solution or a Bed Step that will fit on the Quartermaster?
Something like:
With the lift and airbags filled even partially its tall enough to be a pain to climb up into, and twice as hard when Im trying to balance a dirt-bike on the tailgate without falling when Im climbing into the tall bed. Lots of other truck brands have a similar step, my RAM TRX step is so incredibly convenient and easy to use I want something like that.
Thanks,
I've seen ones that go into the hitch receiver. Have you considered using something like THIS?
Yes, actually I have one of those. However when the tailgates down it’s covered and the bumper is mostly covered too, leaving almost nowhere to step up.
I might just have to order one that fits another truck and see if I can make it work…
Something like:
Thanks,
It sounds like your use of a Quartermaster is the same as my intent; hauling bikes.
My Chevy Colorado ZR2 had an insanely high bed height. Sometimes, I could get up and in the bed, using a motorcycle stand as a step. Other times, I carried a second ramp and walked the bike up, using both ramps.
I've seen other motorcyclists use some manner of steps, including several using a drywail wall platform, like this.
1. Kick my son out of his video game
2. Drag his *** upto the QM bed
3. Get him to grab the bikes when I lift them on the tailgate…
Joke off: Like Mudnut I mostly use one of the wheel as step - one must be careful because slippery when wet, I painfully learned that. And on several occasion i press against the fuel door which pops open without me noticing…
At home no problems, I have a small steps but I don’t bring it with me so an onboard solution would be nice.
Indeed, a second ramp is a good solution. Just not sure Im coordinated enough to pull that off, especially after a long ride where Im almost falling over anyways..,.
As someone adept at finding new and creative ways to huck myself (and my bike); you get used to loading and unloading bikes. It gets much easier with time. Practice and all that...
I find a step helps if the tailgate height isn't sky-high. otherwise, two ramps in parallel, or a double-wide ramp is the ticket. You can walk next to the bike as you clutch it up the ramp.
