Battery drains
Luc Cornelissen
1:31 AM
France
In 2.5 years this is the second time I have this problem.
We travel every year for about six months. We are in Malta right now. No dealers or servicepoints.
I have a freezer in the back to keep yhe food for the dogs.
The freezer is on the secondary battery.
Since a few days the primary battery runs empty over night. From 74% to 48% last night.
During travel it charges again but no more than 75%.
First time I had the problem is not more than 1 tear ago. They changed the battery. But the problem came back and the annoying thing is there are no service points nearby. I am obliged to drive every day.
Called the dealer and he thinks it's the secondary battery which drains the primary. In a few days I can disconnect the freezer so I can see what happens to the primary when nothing is connected.
Anyone had this experience? Should I just change the primary again ?
Grts Luc
Here are some things you can look at, but having a cheap battery monitor can help find the underlying cause (the INEOS gauge is not that accurate):
We are facing the same problem for the last 18 month
Dealer and Ineos Australia can’t find what causes the sudden and random battery drainage
On top of that problem the charging software seems to be faulty as the alternator delivers no charge after 70 %
So sorry no solution but the message
You are not alone with this problem
Weird. Definitely not normal. I just got my vehicle back on the road after overseas shipping and transport. Last saw it in last week of November, got it back start of this week. Total time without being driven was about 2 months and about 5 minutes of being started to load unload I’m guessing plus the doors all open do compliance and bio security checking at the border. I handed over at 98% battery (dual battery Australian diesel trialmaster spec) and got it back at 78% charge on Monday. Have driven it about 1 hour in total now and is sitting at 83% this morning. Doing a 4 hour drive this weekend so that should get it in the high 90s again.
Battery drain is definitely a fault, not a normal “feature”.
Mine has the same issue and charge ranges between 70 and 80%.. for sanity, I occasionally trickle charge it off the mains and it does go to to almost 100% and holds to above 90% for a reasonable time thereafter with regular use. My dealer pointed out that I should only charge it using the live terminal in the engine bay, and not by connecting to the battery terminals directly. Apparently the ECU doesn’t like it..
I do recognise that if you leave it for an extended period, 14 days or more, it goes back to the 70-80% range. One thing I have noticed is that it’s never discharged to the point it won’t start but that maybe unique to my particular circumstances. I should add that mine is a single battery set up and was in the first 600 vin numbers so pretty early.
The onboard SOC is inaccurate, unless it is re-calibrated every 2 weeks or so - it depends on car usage. By that I mean have the battery is actually fully charged and the console is saying 100%. Otherwise it can become wildly inaccurate with SOC after 2 weeks.
You get more accurate information if you look at the charging rate in amps which the car also gives. I had 10 years of doing this on the Patrol, so I can make an educated guess. If everything is working properly you have, broadly speaking, a good charge on the battery if it is around 5 amps or lower (zero amps can take a few hours). 20 amps or above means it is needs a good charge. Look at the charge rate about 5 minutes of starting the car, after the CTEK S120 and car have run its start up tests.
A cheap battery monitor is more accurate over the longer term than the INEOS SOC.
I have been studying the onboard system for the last 12 months, it is better than nothing but far from precise. Only properly setup up shunts are accurate.
Wait quick question without reading every battery thread here.... Are you saying the screen that shows me my battery charge and Amps when charging is not correct? Or some sort of device under my rear seat isn't accurate? Sorry I haven't dove into my dual setup yet since so far it works fine and I have no battery drain.
The SOC is only ever an estimate and on my car it can become inaccurate quickly unless re-calibrated every two weeks or so.
My car also has a CTEK250SE and a solar panel, so it is not OEM. But those two things help me to keep both batteries charged.
So is that something the dealer does for re-calibration?? Are we saying the display is so far off its not trust worthy or its not perfect?
Apparently they can change some parameters, I just live with it.
I have a cheap battery monitor fitted and I use the amps charging.
