General B58 performance tune
FlyingTexan
9:38 AM
BlueSpark really let it rip. Pretty impressed with these numbers.
Horsepower: 286 to 430
Torque: 331 to 464
My worry hasn’t been the engine. There’s TONS of B58s running 550hp+ and living long lives. The ZF tranny used was a little bothersome with its 350ft/lb limit but again there’s many guys running 500+ at the wheels with 50k miles doing it an no issues. I was reading from an engineer who said the real limiting factor for longevity is the trannys ability to cool itself so even the zf45 version was safe to 700nm worth of power. Since it’s not going to be a track car running super hard for 20min straight at a time it shouldn’t have any issues. If there’s any slippage then I’ll turn it down and upgrade the tranny to match but should be good to go. Will be interesting to see how it handles and daily drivability. I haven’t exactly wanted for more power but I can definitely feel it’s at its limit.
Should have it in Wed/Thur and will report back.
I a taking delivery of my new Grenadier next week, and adding more horsepower is something I have been researching quite a bit. Please let us know how your upgrade works out. Very interested. Thanks!
The Racechip tuner and throttle controller set up from Titan Motorsports works great.
I went with TDI for it's eco setting. 325 hp / 349 pounds feet of torque and 18 mpg.
As an update the BlueSpark has made it awesome. I can really feel it launch and hear the turbo going as it's shifting through gears. I love it and I'm glad I did it. I left it at it's default of 430HP, I haven't done a dyno with it but I find myself punching it every time I get in because I just like feeling it dig down and go. Absolute night and day difference. No fuel numbers as of yet. Haven't had a long road trip to measure.
There is no way this thing is getting 18mpg. The closest I got was 16.5mpg and that was at very high altitude and babying it. The MPG on the dash isn't legit it's using Imperial gallons which is 20% more.
I do not go off the onboard systems for mpg or altitude, they are notoriously wrong. Are you on a tune? The added torque is key. At 56 mph that is what I get. The mpg drops quickly over 62 mph.
How many miles on it so far? Have you been monitoring the gearbox temp, while in 430hp mode?
Is there also a curve optimized for fuel economy?
I am not sure you are going to see crazy gear box temps or failure until you are exceeding the stock HP/Torque for a period of time.. Driving on the highway or just around town isn't going to do it... Towing something heavy up a long hill absolutely will...
About 400 miles so far. You’d have to check their website but they say 10% better fuel economy, will take some time for me to be able to test that one at the pump.
There’s a lot of research you can do on the zf transmission but generally this particular tranny is known to be well underspec for its limits. Many people are running more 500Hp through it without slipping. There’s no slipping through any of the gears through the entire range. I did a fluid change and put valvoline’s ATF in. I’ll probably do a sample down the road. The failures have been associated with cooling limitations but the IG runs so cool anyway I’m not concerned about it. I definitely enjoy driving it more and glad I did it. It just felt a little anemic to me with the stock HP. Others are fine with it, that’s perfectly fine, but I really like the increase in passing power.
Gents, any perspective you can share on the costs - for TDI and BlueSpark? More power is always tantalizing!
You can buy it now on their website. I'm not sure if they're still doing the 10% off. I went for the better unit and added the bluetooth option.
Very interesting. Not an owner at the moment, but having had issues with Adblu and the loud rattle of my late model grand Cherokee, I feel I’m leaning towards the petrol variant of the quartermaster. Very close to making a D.
So grabbing the petrol version with a nice tune should be on the cards. Especially as I do tow a 2.5T offroad caravan. Par for the course for as we reside in North Queensland.
Only concerns are:
- lower torque but chip should help
- tranny not as strong? Perhaps a bigger or adding oil cooler.
Cheers all.
Any update on the mileage or performance over the last two months? Did you buy it direct from the UK? How was shipping?
