Aux switches question
Did you use a multiple meter on the wires after install to check circuit? Have you checked for a blown fuse? Was the car on or the PWR switch on when you flipped on Ext2?
Didn't have a multimeter on hand, ordered one for tomorrow. Yes the engine was running, I turned on the power switch and then the Ext2. So I understand there's not need for a second aux battery to make Ext2-5 work, correct?
Correct - did you try flipping polarity?
Ext2 to EXT5 are all part of the high load aux power option, so they should all work if installed. Rok Dr Guide states:
I didn't realize dealers were adding switches as options. Thought it was just factory. But anything is possible.
The only way for a dealer to add them would be to order a lot of parts and wiring
