Diesel At what stage to the dpf fans come on?
1:14 PM
Can anybody shed some light on where in the dpf burn cycle the fans are activated? Do they go on after the burn is complete, or are they on for the whole process? Generally if they go off and I’m nearly at my destination, I will drive a little longer till the whole thing is finished. It’s not always possible, and would like to know if I’m wasting my time doing this as the actual burn maybe over?
You can monitor the progress in the temperature screen, you will see the oil temp rise to close to 100 as the engine moves into high temp mode to facilitate the burn. I find the fans stay on for the entire burn, nice to finish if possible but you won’t break it if you interrupt by shutting down the engine (you will just get the stink eye from those around you while the fans keep running in hovercraft mode).
