Q&A Americas Are there footwell electrical ports?
Stu_Barnes
Fixer & General Dogsbody
8:45 PM
Los Angeles
4:45 AM
Does that mean missing switches in the overhead console then?
Vote:
joejet
4:45 AM
Far far away
Well there are wires connected to the switches in the footwell
see rovie's post here:-
https://www.theineosforum.com/threads/high-load-auxiliary-switch-panel.12410279/post-1333178576
img_2080-jpg.7812114
Vote:
Beormund
4:45 AM
Kent, UK
Vote:
TheDocAUS
1:45 PM
Eromanga
So positive and ground terminals and heat shrink wrapped - is that correct? Will there be enough room behind the trims for Deutch plugs or USB sockets?
The provided link answers the question you asked. Yes is the short answer, if you use a Deutsch DT plug (not sure if a DTP plug would fit).
Vote:
4:45 AM
And yet Ineos are saying officially no?
Isn't it sort of irrelevant what other markets are getting when the question is specific to the US market? Otherwise, I could show them a picture of a diesel engine under a Grenadier bonnet...
The other answer of course is that the definition of a "port" has been interpreted differently?
Vote:
TheDocAUS
1:45 PM
Eromanga
Looking at the supplied picture in the footwell I could install a Deustch DT plug in that position on the cable ends, regardless of what INEOS says. Same goes for the bonnet/hood outlet.
You could also use a butt connector with a dual wall shrink tube, giving you a waterproof seal.
You can always run your own cables, it is not rocket science, but if I can use a supplied one I will.
Vote:
4:45 AM
Yes but the question appears to have been answered that they aren't getting the cable ends.
Vote:
DenisM
1:45 PM
Inline butt connector + shrink wrap seems the way to go so that the Deutsch connector is more accessible.. (y)
Vote:
Stu_Barnes
8:45 PM
Los Angeles
I interpreted this as having a usb port or a std 12V outlet port mounted in the footwell, and not the tail end of a cable behind a kick panel.
Vote:
4:45 AM
So is there a supplementary question:
"Are there footwell electrical cable ends, prewired to the overhead switches, in a similar fashion to the vehicles being delivered in Europe?
If not, will there be blanks in the overhead switch panel?"
Vote:
