Q&A Americas Are all Grenadier models able to accept bolt on accessories if not ordered initially?
hustlehard285
7:41 AM
Colorado
Example: If I order a base model Grenadier with no rock sliders, is it still built with the bolt patterns for Ineos branded rock sliders? If I decide to buy them a year down the road, are the bolt holes going to be there for me to install? Obviously there's things like Safari Windows which probably aren't available after the fact, but things like the Tow hitch, Rock sliders, exterior ladder, are we able to install these items if we order them after our delivery?
Ineos have been very open with the accessory providers, so there is likely to be a huge amount of (blingy tat) carefully curated add ons. We have been warned that the safari windows, axle lockers, extended electrics, additional battery, and winch will be very expensive to add after the fact.
Eventually there may be cheaper aftermarket alternatives, but the factory installed items are high quality; consider the winch also includes re-rated front springs to suit.
Ineos have been very open with the accessory providers, so there is likely to b a huge amount of (blingy tat) carefully curated add ons. We have been warned that the safari windows, axle lockers, extended electrics, additional battery, and winch will be very expensive to add after the fact.
You can't add the safari windows, diff locks or hi load wiring afterwards.
Not possible on the first two or practical on the wiring.
In the UK you can make changes right up until the contract is issued / signed.
The only thing here is you can’t change between the commercial and “car” options.
The tow bar has not been confirmed if you can add it on after you have built not the tow bar but the wiring loom is not there, however I would be surprised if it’s not just a plug-in to the loom.
In the UK the rock sliders and steps are dealer fit anyway the rear ladder is pre installed but should be easy to add, anything without wiring is easy really.
I assume that a ‘Tow Hitch’ would not be too hard to bolt on, but the necessary electrics (to control brake lights, turn signal indicators, etc.) might be a very different story.
