Another Dual battery thread. We are all lost down here! 🥺
nasmo
10:19 PM
Kuwait
A very short story, maybe ..!
I ordered the car with Aux setting however opted for premium sound which is why we didn't have the dual battery option when I initially placed the order. The dealer (in Kuwait) thought that Ineos stopped making the dual battery system. A year later I get my car.
I have a winch fitted, few LED lights, two fridges. I needed a dual battery setup, the dealership tells me the following:
1- We can't set it up now since the car already arrived... it can only be fitted at the factory when the order was palced.
2- We have no wiring, mapping, guide, you name it, we know nothing about the dual battery system or how to operates or how it functions.
3- If you decide to play around with electricals and you could literally put your warranty at risk if something goes wrong.
Without any prior research (my mistake) I went ahead and bought a 100ah lithium battery as an attempt to have one of the top electricians install it using a redarc or ctek setup (which are both widely available here). I was told that there is no battery holder or mount and the subwoofer (JBL Nano) will be thrown out, which is stupid! Cant the subwoofer fit somewhere else ? comeon.
Then the electrician proceeds to tell me that the second battery will serve no purpose at all other than jump starting the main battery shall it fails , he believes that everything is wired directly to the main battery, every point, every switch.
I was told to return the 100ah lithium battery that I bought and invest in a jump-starter kit (lol?), there is no way anyone in the region where I live is willing to try and divert all accessories/winch to the aux battery and keep the main one for ignition.
Can someone kindly direct meon what you do in my place? Any advice or guidance ?
First, I would find a new top electrician. Personally, I would dump the shitty 300 dollar subwoofer and put the second battery and new fuse block specifically for accessories wired from said battery under the seat. Ineos chose to set things up this way for ease of install, there's no need to replicate their 1 + 1 system, if it isn't already installed. Had I known what they were doing, I would have just ordered a base unit with lockers and fitted it all myself.
You need to locate an auto electrician with experience in dual battery setups. I would suggest a Redarc or Victron DC to DC charger between the main and aux battery. More suggestions below.
A dual battery can be added after the car is built. But they are not the same as the factory dual battery option. If you were in Australia I could suggest auto electrician names.
BATTERY BOX
The easiest way to add a dual battery is to use a battery box with a DC to DC charger already fitted to the box. You run cables from the main battery with a 50 amp Anderson plug (fused) which you plug into the battery box. Here are some battery box choices in Australia here. You need to find similar providers in the Middle East. I know Redarc has some dealers in the area. I can see 2 listed for UAE.
BATTERY BOXES
  1. KickAss Battery Boxes. My mini review here;
  2. The DRIFTA Battery Box. My mini review here;
  3. Hardkorr Battery Boxes (also marketed as the CAOS Power Battery Box);
  4. Thunder battery box customised by Accelerate Off-Grid Touring, or just the based model Thunder Battery Box here;. Also marketed under the name Drivetech 4x4 Heavy Duty Battery Box - DT-02008. My mini review here;
  5. Thumper Battery Boxes here;
  6. Ardent Battery Boxes here (with 1200W inverter);
  7. Mueller Energy Lithium Battery Box here (no DC to DC charger just a BMS);
  8. BMPRO Power Station (with built in inverter and 12 power outlets);
  9. Baintech Lithium Power Tops in 150 AH and 200 AH sizes.
  10. JTS Power Easy here;
  11. REDARC GOBLOCK (Premium pricing) here;
  12. EcoFlow DELTA 2 Max (you need an EcoFlow alternator charger to charge at the full rate, the cig socket is limited to 8 amps, thanks @Loc Nar);
  13. Entry level ARK PowerPack 3 here;
  14. The whizzbang POWER BOX Premium range here (3 models, 6 colours). Super premium pricing;
  15. Not really BB’s, but Enerdrive-Dometic is famous for their 4X4 Canopy Power Systems. More suited to a canopy on the QM Cab Chassis. I am not aware on any install in the IG. A new level of pricing compared to the BB’s. Tool Box Centre offers something (Redarc gear) as does MW Toolboxes (Victron gear) and Projecta Power Boards (Projecta gear);
  16. National Luna Battery boxes here (2 colours);
  17. Brown Davis DYI powerboard (5 models);
  18. Battery Box for the DYIer here (by MSA4X4) and Front Runner offers something similar here; and
  19. The Power Easy Expedition Battery Box here, with Expedition Weatherproof Lockable Case, DC to DC Charger, AC Charger and Inver
You need to locate an auto electrician with experience in dual battery setups. I would suggest a Redarc or Victron Dc to DC charger between the main and aux battery. More suggestions below.
BATTERY BOX
The easiest way to add a dual battery is to use a battery box with a DC to DC charger already fitted to the box. You run cables from the main battery with a 50 amp Anderson plug which you plug into the battery box. Here are some battery box choices in Australia here. You need to find similar providers in the Middle East. I know Redarc has some dealers in the area. I can see 2 listed for UAE.
BATTERY BOXES
An amazing input Doc! So much information here I am speechless.
So unfortunate I have to resort to a battery box though, I am trying to find a way to fit the 100 ah battery under the passenger seat and relocate the subwoofer somewhere else. I already have the RedArc option ready here except electricians are clueless if once installed it will function the same way as the factory installed, the warranty issue is a big deal here.
Besides a second battery, the aux battery set up just provides the CTEK120. You can orest the battery holder from Ineos. Now the difference between the redarc and the CTEK. The CTEK is a pass through system. This allows the system to pass energy back and forth. So you can charge the second battery and the second battery can trickle charge the main battery. The redarc dc to dc allows energy to flow one way. From the main battery to second battery. The CTEK provides the ability to jump start your car if need be, a problem that you won't need to solve with you jump pack.
You can buy a lithium battery that is size of the Ineos dual battery. By a holder and than have the electrician connect your dc to dc. The next step is to move the fuse you want to run off the aux battery. Then you are all set.
ADVAS great input thank you!
I made the bitter mistake of purchasing a 100 ah battery from Varter Such as this one
and not knowing the fitment before hand. I will need an electrician to work around this it shouldnt be hard to find a space in that compartment. Many folks are telling me to install and secure the battery there without a proper holder, we do have the convenience here to customize one.
There's no reason why a battery couldn't be installed in the conventional manner (using the second house battery to power a fridge, winch etc). The existing battery would then be just used for starting.
You can buy a generic battery tray to bolt to the floor for little money from such as Amazon.
You would need a separate 12v cigarette lighter socket to power the fridge from your house battery. You could connect a winch, solar panel to that house battery if required.
I can't see a reason why this would affect your warranty.
Hi Nasmo. Sorry I’m late to this, but hopefully it can help somebody if not yourself :)
I have a field master, so only the one starter battery with the sub woofer on the right hand side. I don’t think there is anything necessarily wrong with the Ineos ‘dual battery system’, but for what I do with the vehicle, I much prefer to have an independent lithium battery powering the accessories. Lithium is vastly superior to AGM or lead acid batteries for running fridges and lights etc. There is no comparison.
I have removed the subwoofer from its original location, and simply scooched it back toward the cargo area, rotated it 90 degrees, and strapped it down on some rubber foam. Now there is space for a quality 100aH lithium battery, which is also strapped down using factory studs with some M6 eye bolts. So far so good.
Now the most complex part of all this is manufacturing a plate to mount a DCDC charger. Personally I have always used CTEK, and continue to do so, but Victron and Redarc is all good stuff. Whatever your choice, you must design a mounting plate for your DC-DC charger to live over the handbrake cable. A good machine shop, or even a good carpenter can help out if you feel this is beyond your skills.
Now I’m going to gloss over the re-wiring part of all this, mostly because its covered in excellent detail here: https://www.theineosforum.com/threads/dual-battery-setup-modifications.12413300/
But essentially you are simply going to leave all the main vehicle functions untouched, and re-route consumer type activities to your auxiliary / service/ leisure battery. In my case I am powering an ARB 60l fridge, a twin air compressor, the interior USB outlets, plus some additional USB outlets in my drawer system in the cargo area, and the auxiliary power outlets on the roof and footwells.
It’s really not that difficult or risky, providing you keep everything fused appropriately, and use correct gauge wiring.
I lived in the Middle East for a number of years so I can appreciate it is difficult finding the right people to help with this sort of thing!
Good luck:)
Good luck:)
GP Factor sells mounts for CTEK and Redarc DC-DC chargers.
Yes I saw the GP factor mounting kits, also the black sheep offering. Nothing against them, I bet they work swimmingly. My own version is a 6mm aluminium plate with 4 holes for screws covered with felt (to eliminate any vibration). There are 2 x 60mm spacer posts to level the plate. You could just as easily use a piece of 8mm ply if that was easier. Really simple, cheap, and infinitely configurable.
The new Redarc Alpha DC-DC charger has a function that allows you to provide power to the cranking battery for emergency starts.
Thread 'Auxiliary Battery Removed from New Vehicle Specifications'
https://www.theineosforum.com/threa...ved-from-new-vehicle-specifications.12418537/
This other thread may help.
