Android 16 on MY2023?
chrsbe
2:12 PM
Sternwartestraße, Wien, Österreich
Hi!
My new Pixel 10 running Android 16 appears to be incompatible with the Android Auto version installed in my Grenadier.
My dealer has confirmed that the vehicle already has the latest available software update.
Where can I find the Android Auto version and the head unit software version in the Grenadier’s infotainment menus?
Anyone else with A new Pixel Phone?
C
It briefly connects and then immediately disconnects, after which it reconnects again in a loop. Occasionally it works, but the connection is unstable. The highspeed USB cable is known to be good. Standard troubleshooting steps such as clearing the Android Auto cache and resetting the connection have not resolved the issue....
Hi!
I'm running Android 16 with no issues in my September 2023 built Grenadier with the head update. It also worked OK before the head update. Both our phones are Samsung though and we run wireless 🛜. I presume you have checked in phone settings in the Android auto App on the phone 📱in particular the auto start setting is set as "always"
I run Android 16 on pixel 9. No issues, I did recently have to turn off my phone and restart it but connection was perfect.
Pixel 10 and 6 both running android 16.
Have you tried it with the wireless + Bluetooth link instead of via cable?
I checked and tested several Android Auto settings. The 2023 Grenadier does not support wireless Android Auto.
Once, a warning or information screen appeared on my phone stating that the phone could not verify the car’s system security and that the vehicle might need an update. Unfortunately, I didn’t take a screenshot, and the message hasn’t appeared again.
Next, I will try an Ottocast wireless adapter. All my older pixels used to work fine.
The Ottocast adapter works fine on a MY2023 Grenadier. I've had one operating for 2 yr👍
If it works on a wireless 🛜 adapter then you are going to have to suspect that the cable is " iffy".
Yes and no. I believe the phone does not accept the system for some security-related reason. Therefore, it’s quite possible that the phone will accept the wireless adapter. At least, that’s my hope.
Have you reset the vehicle date after the new year bug?
Android auto doesn't like it if dates don't match and pops up a security alert.
Well remembered, my Android Auto through a hissy fit after year's end. But when I checked the vehicle the GPS had reset the time automatically. If you haven't got it on auto it could be any year 🫣
