Altimeter Recalibration?
Jeff Olson
12:50 PM
Olympia, Washington
Is it possible to recalibrate the altimeter?
We live on a 50-foot bluff above the Puget Sound, yet my altimeter says I am 32 feet below sea level. I doubt the Puget Sound is below sea level…
There is no actual recalibration, it should recalibrate after losing GPS signal. It also has a +/-100ft range of accuracy
Altimeters are pressure instruments and in an aircraft can be recalibrated for altitude hight etc as a pilot I'm ok if I can see the ground in a grenadier it's not a problem.
If youre at 14000 or 14100 ft, the difference isnt going to matter. What matters would be your change in altitude as you travel (if at all). This isnt a surveying tool. If you need absolute, download a usgs map into something like avenza, or whatever people are using nowadays.
I spent time driving on the beach and ignore the altimeter. Would be very useful feature if it actually worked or it could be recalibrated. I'm on the sand at low tide and altimeter is indicating -80 ft.
