And how do we feel about the EFB batteries, I was expecting AGM at this price point and use case.
Australia, France, Germany & UkAlso recall Oz had a longer warranty than Europe one's. Forget whether it was the paint. Out and about at the mo so will look up later.
Multiple, 4 deutsche plugs on the roof, under the tie down rails, one high Amp NATO plug on the rear under the bumper, additional outlets under the dash and in the engine bay.Where is the power outlet from the second battery? Switched from the roof panel?
Really? Didn't see these! Will be on my checklist if I visit again my dealer again!... under the tie down rails, one high Amp NATO plug on the rear under the bumper, additional outlets under the dash and in the engine bay.
They are only there if you ordered the hi load switch panelReally? Didn't see these! Will be on my checklist if I visit again my dealer again!
Trialmaster!They are only there if you ordered the hi load switch panel
I have optioned them on my FieldmasterTrialmaster!
I only saw the 4 connectors on the roof!
With me it's almost the other way around, but I didn't want the wheels of the FieldmasterI have optioned them on my Fieldmaster
In fact I have all the Trialmaster options on my Fieldmaster
I went with the utility floor not the carpet, got stuck with the carpet mats but will get rubber as wellWith me it's almost the other way around, but I didn't want the wheels of the Fieldmaster, the leather, the carpets, also not necessary, but yes the safari windows, central locker box, ...
EFB batteries are superior for auto stop start vehiclesAnd how do we feel about the EFB batteries, I was expecting AGM at this price point and use case.
Not to mention weight savings of up to 12KGsAGM you only get 50% of the amp rating - ie when voltage drops. Most off roaders & campers in Aussie now install a 205 amp hr LiPo auxiliary battery with a 2000w 240v inverter (like the EnerDrive systems) enerdrive.com.au - to run a 80 /90 ltr fridge & freezer, a dual motor air compresser for tyre inflation, 8t Hydraulic bottle jack & torque wrench. It easily runs the inverter cook top (far better quicker than gas in wind), all lights and other accessories easily. Now there are flat LiPo batteries with Bluetooth monitoring for concealed spacers. Be re-usung some of the wiring loom only.
Or....like you can buy for Mercedes vehicles an OBD plug which renders the stop-start inoperativeI’m so glad the Grenadier has start/stop technology…………………………………………………………………………………………………………………………………with a button so I can turn that shit off!
I read recently that an obd plug (e.g a bluetooth one) should not be left in the socket indefinitely... but I'm not sure why. Mr Mike does anything need to be attached to the said OBD plug...e.g are a couple of the pins shorted by a jumper wire to disable the stop/start function?Or....like you can buy for Mercedes vehicles an OBD plug which renders the stop-start inoperative
I have a bluetooth device in my 200 series permanently without issue, the MB OBD plugs are permanent- in so much as they work when it's in and not when taken out. Interesting to read about the trailer plug scenarioI read recently that an obd plug (e.g a bluetooth one) should not be left in the socket indefinitely... but I'm not sure why. Mr Mike does anything need to be attached to the said OBD plug...e.g are a couple of the pins shorted by a jumper wire to disable the stop/start function?
My neighbour was mortified at the local shops this morning: his v late model C-class 2 door MB.... "failed to proceed"! flat battery. Seems he's working from home mostly and rarely drives the vehicle these days... and he didn't realise he probably ought turn off the engine stop/start each time ...
why do the manufacturers have to make it so hard?
Discovered that for the wife's 2019 Subaru Impreza, an unwired trailer plug in the bumper socket disengages the stop/start![]()
Discovered that for the wife's 2019 Subaru Impreza, an unwired trailer plug in the bumper socket disengages the stop/startI read recently that an obd plug (e.g a bluetooth one) should not be left in the socket indefinitely... but I'm not sure why. Mr Mike does anything need to be attached to the said OBD plug...e.g are a couple of the pins shorted by a jumper wire to disable the stop/start function?
Dog pee poop vomit. I use water resistant seat covers. How does hosing out the floor work with the batteries? Maybe a marine enclosure would work. Be patient, I'm an amateur. Moll is sealed, correct? Does not require vent like typical RV aux batteries?I'm pretty sure every person here that has had children or grandchildren knows what you mean.
Ok not a coke but certainly a bottle of water.
