Airbag failure
minidok
#00833
1:20 AM
Zürich, Schweiz
After disconnecting and reconnecting the central power unit, tpms, diffs and airbag were signalling failures.
Everything but the red airbag error cleared out after short drive.
Does the airbag controll unit somehow react on edges in voltage changes?
So far I did not find a way, how to reset this failure message.
What do you suggest?
Did this happen to others too?
:unsure:
You can try disconnecting the battery again for a few minutes... I can't say anytime I've disconnected the battery I've seen an airbag light stay persistent, but strange things happen sometimes
Thank you @anand. Did try this and disconnected batteries for at least 10mins, but airbag warning is still shown afterwardes.
Did you try a reset, With the key, contact on. Then after everything wakes-up, you press the mute button, and keep pressing him until the screen becomes black and the Grenadier logo reappears. I don't know, maybe it works..
:unsure:
Hi Minidok, is the problem the driver airbag or passenger airbag?
In my case after replacing the ECU (of course they did disconnect the battery) the passenger airbag did show deactivated. Guessing that this a bug. You would need to go to the main menu and re-activate the passenger airbag. It can only be done with ignition ON and gear box in P - you may need to wait for 12 seconds. I have done it on my own and it did work out immediately. So I think a reset will not help here. Small pic shows when passenger airbag is deactivated. 1708622978949.png
In my case after replacing the ECU (of course they did disconnect the battery) the passenger airbag did show deactivated. Guessing that this a bug. You would need to go to the main menu and re-activate the passenger airbag. It can only be done with ignition ON and gear box in P - you may need to wait for 12 seconds. I have done it on my own and it did work out immediately. So I think a reset will not help here. Small pic shows when passenger airbag is deactivated.View attachment 7845126
Thank you a lot @Pat this is indeed a good hint and was in my case applicable too. Though, not the only resolution needed. Warning sign was still on after the passenger air bag has been on again. only a read out and manual reset by the agent could resolve the issue completely. No damage after all.
@mihidok I had a tracker fitted and the installer did something and I also had an airbag warning, no othere wy to reset it apart from a trip to a service centre.
No returned since the visit
Thank you for your reply. It is an airbag fault (red) that shows up in the warning light panel in front of the steering wheel and on the user interface screen.
Disconnecting main battery procedure:
Airbag Failure will not happen, if you let the ecu rest for about 10-20 seconds after switching ignition completle off.
State has been reached if you see information display off and dark, some relais clicking can be heard too.
After this, just remove the negative pole from the battery.
Take care not to short connect the pole again, as this will result in a reboot.
I usually wrap the cable to prevent from any connection.
Since following this, no other airbar-sign errors ever occured.
Not sure how similar this will be but when working on my M4 had to take seats out which popped up the airbag issues even with battery disconnected. To reset I had to keep like you say here but for 30mins and leaving the vehicle untouched for that long as well before it cleared. Wonder if they use that same principle here with Ineos...
Are you saying if you do trigger the airbag error, you can use this procedure to self service the clearing of that warning? No need to go to the dealer?
It has worked for me a few times, say when replacing steering wheels and seats etc... Dunno about the grenny though it was more of a suggestion based on what works on many other brands.
