Give it time and I bet ARB will have air lockers available.
So right you are!That’s what diodes are for
but what happens if you have the locker locked, and the computer doesn't think it should be? Is there a position sensor? Will the computer toss a code, that's part of my question. I doubt it makes assumptions on apparatus position by voltage application alone. Theres got to be a position sensor, don't you think? Even my 96 G closes a position switch for a light.Right... you splice in below the diode and it keeps current from running back up to the ecu sensor. There must be a plug somewhere in line. Wonder if we can make a simple plug in harness and see what happens.
The computer can’t know if you use a diode. It will just function as usual.but what happens if you have the locker locked, and the computer doesn't think it should be? Is there a position sensor? Will the computer toss a code, that's part of my question. I doubt it makes assumptions on apparatus position by voltage application alone. Theres got to be a position sensor, don't you think? Even my 96 G closes a position switch for a light.
May be reasonable, but does it need to be controlled automatically?An aftermarket selectable locker may still have to be used in low range only.
I have sometimes used selectable locker on high range and automatic ones, like Detroit Locker, sure don't know if transfer box is on high or low.
Ugh. But it can know that the factory system ISN'T sending 12v, but the locker is engaged when it "shouldn't" be if the locker has a position sensor.The computer can’t know if you use a diode. It will just function as usual.
If a differential is locked there will be same rotational speeds on both sides so system can't see any strange there. Only on cornering but then your speed wll be low. If the centre diff is locked (which should be to gain any benefit from rear locker) there won't be any front/rear difference either.My concern would be the Grenadier's software which might see the non-normal wheel speeds (front to rear/side to side) as an indication of component failure, loss of stability, or worse.
Find an open area with low traction and make some tests.I believe engaging Low Range turns the ESC completely off vs. locking the center diff only which places the ESC function in ESC Offroad mode(?).
Not all wranglers come with lockersAlong with a hitch, these should NEVER be built with out lockers. HUGE mistake
Build them all with lockers even if it is just a statement to reinforce the “built on purpose” branding. It provides a way to better differentiate the truck. Last I checked they don’t built G-Wagons without lockers.Not all wranglers come with lockers
If they actually built these on purpose. We would have service manuals, we would have the ability to reset our service interval, the update for the Nannie’s would be rolled out by now.Build them all with lockers even if it is just a statement to reinforce the “built on purpose” branding. It provides a way to better differentiate the truck. Last I checked they don’t built G-Wagons without lockers.
Which code reader do you use? I have found that the gas tank meter is very sensitive, and I would love to reset that on my own. ThanksWhile on a group trail ride last week, one of the Grenadiers refused to allow diff locks. It turns out that the owner overfilled his fuel tank and that threw a check engine light. The computer won't allow for use of the lockers if a check engine light is on. Fortunately, I carry my code reader and was able to reset his check engine and then lockers were allowed.
How stupid is it to not allow lockers because of a check engine light! Great way to get someone stuck in a remote place of what might be an emissions sensor or something else minor. This makes me even more motivated to find a backup way to activate diff locks.
This would be the perfect truck if not for the stupid software.
I’ve been using OBDLink MX+ and their app. Works very wellWhich code reader do you use? I have found that the gas tank meter is very sensitive, and I would love to reset that on my own. Thanks
True, but the Carraro axle housings are not necessarily machined the same for diff lock vs no diff lock....The OEM Diff locks are by Eaton so they should be able to supply as aftermarket -
“Manufactured by global engineering specialists Eaton Industries, the front and rear diff locks are standard on Trialmaster model, and optional on all other variants”
