Ad Blue bypass
Cheshire cat
4:55 PM
Cheshire, UK
Having read yet again in detail, the "BMW University' B57 engine training document posted on this forum, I am beginning to change my view on EGR and AdBlue (DEF) deletion!🤔 Coupled with this I have sought other explanations regarding the function of the Cat. converter (= SCR) and the particulate filter (DPF).
The B57 setup in the Grenadier has two devices which separate oil from the gases in the EGR system (precluding the need for catch cans). Further, the non-combustible gases in the EGR system are siphoned off and treated via the DEF /AdBlue system . I hadn't realised the 'subtleties' of this engine until I examined these in detail. The "Euro6" standard, despite my initial 'reluctant squirming" to accept, actually maintains power and torque as well as producing a much cleaner outcome which should enhance engine life. The adherence to regular oil changes using high quality low ash oils is critical also to reduce the gradual build up within the DPF of non combustible deposits....
It's given me good reason to leave well alone...
So endeth the lesson for today🙄
Thanks Denis
Interesting reading and a sound persuasion as to why I should leave well alone also.
My reason for considering otherwise was, a friend who is a haulage contractor running Scania and Mercedes wagons says that AdBlue systems are a pain for him. Like many other contractors, the system has been bypassed to improve reliability bearing in mind many of his problems are actually down to the AdBlue system itself.
Matiassebastian
Production/Transit
5:55 PM
Madrid, Spain
I am wondering, if the system is bypassed, apart from any legal infringements, would a dormant system deteriorate quicker than if in use? I will ask the question when I contact one of the companies that specialise in such work.
I think that as long as you can Bypass it (if possible) in a non Euro 6, nobody would care. When you go back to the Euro 6 Zone then you need to reactive the Ad Blue thing so you are not breaking any laws.
MrMike
11:55 PM
Thanks Denis
I'd be interested to see what issues he is having with DEF, in AU its evaporation issues with mine vehicles operating at high ambient temperatures and are relatively stationary causing crystallisation of the urea.
Cheshire cat
4:55 PM
Cheshire, UK
My friends wagons are mainly salt spreaders but before that, his fleet was doing mainly local work and not many long journeys of more than perhaps 100 miles. He always keeps his vehicles very well maintained.
4:55 PM
San Juan de la Rambla, España
This is one of the reasons mine will be petrol-engined if I can somehow accept the vast amount of electronics in IG. I stopped my purchase project in October ...
One problem source in diesels will be DPF. I just last Monday burned carbon particle deposits from customer's D3.
bemax
5:55 PM
So here's question:
What happens when you run out of AdBlue?
I was in Ireland recently in a rented diesel Opel - and I loved it - but we ran low on AdBlue and a quick google suggested that the vehicle would enter a limp-home state and not run right.
Is that expected of the Grenadier?
I can understand if its the same due to regulations but it would be a shame - stranger things have happened than getting a stick through a tank of ancillary fluids in the bush, and so for actual backcountry troubleshooting it would be good to know how these parts behave when there's a problem or failure.
I presume you get a certain distance to drive and after that it will go into limp moe. A companys seat had a problem with the adblue quality sensor and it allowed to go 1000 or 1500 km before it stops. That should be sufficient to fix the tank or refill it.
DenisM
1:55 AM
If the diesel Grenadier runs out of DEF (AdBlue) it will keep running until the engine is shut down. It won't restart until the DEF tank is replenished.
