Accessories Mounted on Rear Ladder
There's more uses for a high-lift than just jacking up the truck. Even if I were to add one of the hydraulic jacks to my trucks, I'd still carry a high-lift.
Besides, ignorant people think you have an assault rifle mounted to your truck. Apparently a lady called the police on a jeep owner who had their hi-lift mounted across their hood thinking that it was an AR!
Other uses to justify the need of a Farm Jack:
View: https://www.youtube.com/watch?v=w-jE16xQhtg
I used the UTV roll bar mount for a rotoplex gas container mounted to my rear ladder rung. You could easily do this with a water container. It was quite economical and easy to install. Thanks to Amazon.
Would you mind expanding a bit on what you've used to mount this container please?
Could easily be adapted to carry a frame that you could put a jerry can or other item in.
Looks good. Could you add a photo of how the foot of the jack is supported please and a link to fixings used.
Thanks 🙏🏼
Hi Lift mount:
WD40 holder:
Sold as a household trash can which I use it as…a trash can. Attached to ladder rungs by hose lamps (bungee cord is used only to hold lid in place). Custom holes drilled in bottom corners of cheap-piece-of-junk plastic can for drainage.
What did you use to connect the Rotopax?
GP FACTOR
I attached my propane cylinder to the ladder. I happen to have the Le Tech Ladder with the jerrycan holder, but this should work on the OEM ladder just the same. I still use the ladder to access the roof rack with this on.
Here's my post about it:
How much weight will one rail hold? Can you send me the link to the rails?
25 pounds per rail; 50 pounds across 2 rails, dynamic weight. The rails are extremely strong, if you're going crazy, I would keep it to the 50 pounds limit, but camping/driving, they could hold much more.
