Accessories Mounted on Rear Ladder
There's more uses for a high-lift than just jacking up the truck. Even if I were to add one of the hydraulic jacks to my trucks, I'd still carry a high-lift.
Besides, ignorant people think you have an assault rifle mounted to your truck. Apparently a lady called the police on a jeep owner who had their hi-lift mounted across their hood thinking that it was an AR!
Other uses to justify the need of a Farm Jack:
View: https://www.youtube.com/watch?v=w-jE16xQhtg
I used the UTV roll bar mount for a rotoplex gas container mounted to my rear ladder rung. You could easily do this with a water container. It was quite economical and easy to install. Thanks to Amazon.
Would you mind expanding a bit on what you've used to mount this container please?
I’ve used 1” motorcycle handle bar risers to mount my ski rack on the ladder. Very heavy duty and more than suitable for a hi-lift or a jerry can.
Interesting! Do you have a pic of what that looks like?
Could easily be adapted to carry a frame that you could put a jerry can or other item in.
Looks good. Could you add a photo of how the foot of the jack is supported please and a link to fixings used.
Thanks 🙏🏼
Hi Lift mount:
WD40 holder:
Sold as a household trash can which I use it as…a trash can. Attached to ladder rungs by hose lamps (bungee cord is used only to hold lid in place). Custom holes drilled in bottom corners of cheap-piece-of-junk plastic can for drainage.
What did you use to connect the Rotopax?
GP FACTOR
I attached my propane cylinder to the ladder. I happen to have the Le Tech Ladder with the jerrycan holder, but this should work on the OEM ladder just the same. I still use the ladder to access the roof rack with this on.
Here's my post about it:
How much weight will one rail hold? Can you send me the link to the rails?
25 pounds per rail; 50 pounds across 2 rails, dynamic weight. The rails are extremely strong, if you're going crazy, I would keep it to the 50 pounds limit, but camping/driving, they could hold much more.
Latest posts
