Abbreviations on this forum ...
Stu_Barnes
Fixer & General Dogsbody
2:50 PM
Los Angeles
SRT, if you really want an abbreviations list to go in the forum help pages, then please separate the automotive, comms and slang into their respective groups.
ps. brave chap for starting a latin grouping,
ttfn,
sb
Jean Mercier
GG#920
11:50 PM
Sint-Martens-Latem, Belgium
SRT > see link :ROFLMAO:
Serious now, ok I will separate the two lists: Automotive (everybody can use this, even VIN wasn't common language for quite a few including myself) and a "slang" or whatever you want to call it, because this is really a pain in the ass for NNESP or Non Native English Speaking Persons.
10:50 PM
Or you could tell Stu to GTFO 😁
Stu_Barnes
2:50 PM
Los Angeles
(specialized readability table) ;)
I think the automotive is a good idea, if you need it you need it, if not then that's ok.
Slang, if you feel it's essential. Your call. I don't mind but portions of words will be *** starred out, I'm not a fan generally but there are rarities where perhaps expletives are justified, perhaps.....
I can drop it in the Resources section...
Here are a few more.
- A -​
  • AB - Air Bleed
  • ABDC - After Bottom Dead Center
  • ABPV or ABV - Air Bypass Valve
  • ABS - Anti-lock Brake System
  • AC - Alternating Current
  • A/C - Air Conditioner or Air Conditioning
  • ACCC - A/C Compressor Clutch
  • ACCCS - A/C Clutch Cycling Switch
  • ACL BI-Met - Air Cleaner Bimetal sensor
  • ACL DV - Air Cleaner Duct and Valve Vacuum motor
  • ACT - Air Charge Temperature sensor
  • ACV - Air Control Valve
  • ADS - Association of Diesel Specialists
  • AEA - Automotive Electric Association
  • AERA - Automotive Engine Rebuilders Association
  • A/F - Air/fuel
  • AFB - Aluminum Four-Barrel (carburetor)
  • AFC - Air-Flow Controlled
  • AFR - Air/fuel ratio
  • AFS - Air Flow Sensor
  • AI - Air Injection
  • AICV - Air Injection Check Valve
  • AIR-CHV - Air Check Valve
  • AIR-DV - Air Diverter Valve
  • AIR-IVV - Air Idle Vacuum Valve
  • AIS - Air Injection System
  • AIS - Automatic Idle Speed Motor
  • AIV - Air Injection Valve
  • AMGV - Air Management Valve
  • AMS - Air Management System
  • ANTBV - Anti-Backfire valve
  • APDV - Air Pump Diverter Valve
  • API - American Petroleum Institute
  • AS - Airflow Sensor
  • ASC - Automatic Stability Control
  • ASE - Automotive Service Excellence
  • ASIA - Automotive Service Industry Association
  • ASME - American Society of Mechanical Engineers
  • ASRV - Air Switching Relief Valve
  • ASS - Air Switching Solenoid
  • ASV - Air Switching Valve
  • ATA - American Trucking Association
  • ATF - Automatic transmission fluid
  • ATS - Air Temperature Sensor
  • AWD - All-wheel-drive
- B -​
  • BBDC - Before Bottom Dead Center
  • BCDD - Boost-Controlled Deceleration Device
  • BCI - Battery Council International
  • BDC - Bottom dead center
  • Bhp - Brake horsepower
  • BHS - Bi-Metal Heat Sensor
  • BMAP - Barometric and Manifold Absolute Pressure sensor
  • BP - Barometric Pressure sensor
  • BPA - By-Pass Air solenoid
  • BPEGR - Backpressure EGR
  • BPS - Barometric Pressure Sensor
  • BTU - British Thermal Unit
  • BV - Bowl Vent port
  • BVT - Backpressure Variable Transducer
- C -​
  • C-3 - Computer Command Control system
  • C-4 - Computer Controlled Catalytic Converter system
  • CAM - Choke Air Modulator switch
  • CANP - Canister Purge solenoid
  • CAS - Cleaner Air System
  • CAT - Catalytic Converter
  • CAV - Coasting Air Valve
  • CBVV - Carburetor Bowl Vent Valve
  • CC - Catalytic Converter
  • CCC - Computer Command Control; Converter Clutch Control solenoid
  • CCEGR - Coolant Controlled Exhaust Gas Recirculation
  • CCEVS - Coolant Controlled Engine Vacuum Switch
  • CCIE - Coolant Controlled Idle Enrichment
  • CCO - Converter Clutch Override
  • CCS - Controlled Combustion System
  • CCT - Computer Controlled Timing
  • CCV - Closed Crankcase Ventilation system
  • CEC - Combined Emission Control system; Computerized Emission Control system; Combination Emission Control
  • CES - Clutch Engine Switch
  • CI - Cubic Inches
  • CID - Cubic Inch Displacement
  • CIS - Continuous Injection System
  • CKV - Check Valve
  • CLC - Converter Lock-up Clutch
  • CO - Carbon Monoxide
  • CO2 - Carbon Dioxide
  • COC - Conventional Oxidation Catalyst
  • CP - Crankshaft Position sensor
  • CPRV - Canister Purge Regulator Valve
  • CPS - Canister Purge Solenoid
  • CPV - Canister Purge Valve
  • CRV - Coasting Richener Valve
  • CSOV - Canister purge Shut Off Valve
  • CSSA - Cold Start Spark Advance system
  • CSSH - Cold Start Spark Hold system
  • CTAV - Cold Temperature Activated Vacuum
  • CTO - Coolant Temperature Override switch
  • CTS - Coolant Temperature Sensor; Coolant Temperature Switch
  • CTVS - Choke Thermal Vacuum Switch
  • CV - Check Valve
  • CWM - Cold Weather Modulator
- D -​
  • DBC - Dual-Bed Catalytic Converter
  • DC - Direct current
  • DEFI - Digital Electronic Fuel Injection
  • DFS - Deceleration Fuel Shut-off
  • DIS - Distributorless Ignition System
  • DLV - Delay Valve
  • DP - Dashpot
  • DPDT - A double-pole, double-throw switch
  • DPST - A double-pole, single-throw switch
  • DRB II - Diagnostic Readout Box II
  • DS - Detonation Sensor See knock sensor
  • DSAV - Deceleration Spark Advance system
  • DV - Delay Valve
  • DVOM - Digital Volt-Ohmmeter
  • DVTRV - Diverter Valv
- E -​
  • ECA - Electronic Control Assembly
  • ECC - Electronic Controlled Carburetor
  • ECM - Electronic Control Module
  • ECS - Evaporation Control System
  • ECT - Engine Coolant Temperature sensor
  • ECU - Electronic Control Unit
  • EDIS - Electronic Distributorless Ignition System
  • EDM - Electronic Distributor Modulator
  • EEC - Evaporative Emission Controls
  • EEC/EEC-I/EEC-II/EEC-III/EEC-IV - Electronic Engine Control systems
  • EEGR - Electronic EGR valve
  • EFC - Electronic Feedback Carburetor; Electronic Fuel Control
  • EFE - Early Fuel Evaporation
  • EFE TVS - EFE Thermal Vacuum Switch
  • EFI - Electronic Fuel Injection
  • EGO - Exhaust Gas Oxygen sensor
  • EGR-EPV - EGR External Pressure Valve
  • EGR-EVR - EGR Electronic Vacuum Regulator
  • EGR-FDLV - EGR Forward Delay Valve
  • EGR-RSR - EGR Reservoir
  • EGR-S/O - EGR Shut-Off
  • EGR-TVS - EGR Thermal Vacuum Switch
  • EGRV - EGR Vent solenoid
  • EGR-VCV - EGR Vacuum Control Valve
  • EGR-VSOL - EGR Vacuum Solenoid
  • EGR-VVA - EGR Venturi Vacuum Amplifier
  • EHCV - Exhaust Heat Control Valve
  • EIS - Electronic Ignition System
  • ELB - Electronic Lean Burn
  • EMF - Electromotive Force, or Electromagnetic Frequency
  • EPA - Environmental Protection Agency
  • EPC - Electronic Pressure Control
  • EPR-SOL - Exhaust Pressure Regulator Solenoid
  • EPR-VLV - Exhaust Pressure Regulator Valve
  • ERS - Engine Rpm Sensor
  • ESC - Electronic Spark Control system
  • ESS - Engine Speed Sensor
  • ESSM - Engine Speed Switch Module
  • EST - Electronic Spark Timing system
  • ETC - Electronic Throttle Control
  • EVAP - Evaporative emission control system
  • EVCR - Emission Vacuum Control Regulator
  • EVP - EGR Valve Position sensor
  • EVR - EGR Vacuum Regulator
- F -​
  • FAP - Forced Air Pre-heat system
  • FBC - Feedback Carburetor system
  • FBCA - Feedback Carburetor Actuator
  • FCS - Feedback Carburetor Solenoid; Feedback Control System; Fuel Control Solenoid; Fuel Control System
  • FCV - Fuel Cut-off Valve
  • FI - Fuel Injection
  • FVEC - Fuel Vapor Emission Control
  • FVR - Fuel Vapor Recovery system
- H -​
  • HAC - High altitude compensator
  • HAEC - High Altitude Emission Control system
  • HAI - Heated Air Inlet system
  • HC - Hydrocarbon
  • HCV - Heat control valve
  • HEGO - Heated EGO sensor
  • HEI - High Energy Ignition
  • HSC - High Swirl Combustion chamber
Stu_Barnes
2:50 PM
Los Angeles
forgot to add,
ZDKZENTRALVERBAND DEUTSCHES KRAFTFAHRZEUGGEWERBE
Jean Mercier
GG#920
11:50 PM
It's OK, I will not insist on the "slang" ... after all, Google knows everything ;) and you are the boss of this forum (y)(y)🍻
11:50 PM
There is (at least) one missing: SRT - single requester terminal.
A particular mode for which an application on a system /36 was programmed.
Stu_Barnes
2:50 PM
Los Angeles
over my head
11:50 PM
Don't worry. Absolute insider talk. But it popped up from a long gone memory: We wrote SRT and MRT mode applications - and even most of the very experienced programmers didn't know what it is.
SRT: single requester terminal: One complete copy of the program for each user (i.e. terminal) was in memory.
MRT: multiple requester terminal: A predefined number of terminals could start and share the only copy of the application in memory.
That way, we could save a lot of memory (which was measured in Kilobytes in that time) and secondly control how many user could run the application at the same time.
And the System /36 was one of the most reliable systems in that time. Starting at around 90'000 DM - which was the equivalent about three Porsche 911.
DenisM
7:50 AM
- A -​
  • AB - Air Bleed
  • A/F - Air/fuel
- B -​
- C -​
  • CI - Cubic Inches
  • CKV - Check Valve
  • CV - Check Valve
- D -​
  • DLV - Delay Valve
  • DP - Dashpot
  • DV - Delay Valve
- E -​
- F -​
- H -​
  • HC - Hydrocarbon
I notice the global "F" word is alluded to regularly. The acronym F*ck , just so we're all on the same page stands "Forum Unified Collective Knowledge"
Thus, to use the expression /acronym "FFS" is actually appealing for a course of action which will be 'for the sake of' a benefit to all! OK?
Well that's my explanation today for my 10yr old grandchild (and @Jean Mercier!:love:) which
I thought might "be of benefit to all" ;)
7:50 AM
And here I thought it was a legal charge For Underage Carnal Knowledge
