Wolfbox Installation Pro Install Resource - Upstate New York
NorthShale+1
5:07 PM
East Coast
Had the Wolfbox G900 Pro with 67 Designs mount professionally installed and thought others in the upstate NY/Albany area might benefit from our experience.
The work was done at Boomer McLoud on Central Ave in Albany which has been around for a long time. We were quoted $300 for the job which we felt was fair. It ended up taking longer than they anticipated but they honored the quote. A friend is bringing her Grenadier to them for the same work in a couple of weeks and they are giving her the same rate. They got the learning curve of the install out of the way with us and we are very happy with the results.
We got the package that included the hardwire kit and polarizing lens attachment for the front camera. We also ordered the 33’ rear camera replacement cable. We had them hardwire it to an ignition tap in the fuse box by the steering wheel so it powers on/off with the key. With this it also powers up from the power button on the mirror without turning the key as long as the Grenadier is “awake.” The GPS puck is above the overhead panel and works perfectly there.
We mounted the camera in the same spot that’s been highlighted in a few of the installation videos, inside at the top of the large rear window as far to the left edge (when facing the closed door) as was possible. As has been noted, the sticky tape that comes with the Wolfbox to mount the rear camera is useless - we used a small screw to mount it.
If you reach out to Boomer McLoud, speak with Richard, the owner.
For anyone who may be considering reaching out to the previously referred to vendor we used for our Wolfbox install, as I mentioned, the job took longer and was more involved than they anticipated (he quoted it over the phone never having seen a Grenadier as we are located an hour away) and while he honored his original quote for us, he pointed out that future installs are likely to come in at around $450. Even at that rate we would have felt it was fair and given the quality of their work we would absolutely use them again.
Buyer beware. I had the camera installed on the left side above break lights in the blank. WOLFBOX advised installers not to angle it. The 900 Pro has zero horizontal back up line adjustments as had earlier versions. It is now useless as a backup camera. Cmon Woflbox.
I don't use my Wolfbox as a backup camera at all due to the wide angle lens which distorts the center and the edges...I still use the OEM backup camera for it's intended purpose.
I had on installed in Savannah, GA by a local car stereo installer. they did a good job with the install - very clean. definitely an upgrade I'm happy with. they charged me $300 and said it took them about 3 hours.
I've gone from staring at a spare tire to actually knowing what is behind me. not a big fan of camera mirrors, but that's the option...
like someone else, I sitlll use the backup camera when reversing.
